  2. Mixed-Signal Design
  3. Associating a spice netlist to a symbol
  • Subscribers 64
  • Views 16530
sidz
sidz over 9 years ago
Hii,
I am new to cadence. I have made a layout for an inverter in Cadence Virtuoso 6.1.5-64b  and verified DRC LVS and PEX using calibre. I am having spice netlist of the extracted inverter layout. How do I associate this netlist to a symbol for further post layout simulation?
Thank you in advance.
    Calibre (a Mentor tool) should be able to produce an "extracted view" as an alternative to a SPICE netlist when doing extraction. If you do it this way, it will make it much simpler to switch to that view - you either change the order of the view names in Setup->Environment in ADE (assuming  you're using ADE) or you create a config view using the  hierarchy editor where you pick the view to use for the cell you've extracted to be the name of the extracted view you've created - and then you open ADE with the config view as the design.
    This is much simpler than trying to use an external SPICE netlist; there are posts that describe how to do that, but why make it more complicated than it needs to be?
  • sidz
    Thank you very much, Andrew.
