  2. Mixed-Signal Design
  3. pwl & timely bias trigger with different values
  • Subscribers 64
  • Views 3943
Charanraj Mohan
Charanraj Mohan over 9 years ago
 I have two questions, as follows-
1. Since I need to define pwl- data points (more in number) to bias a circuit, I don't want to put them in series like a long chain of pwl source, as the limit of a pwl source is only 50 datapoints. Is there any alternate where I can just simply define (voltage, time) in an instance and it generates the whole bias ???
2. I want to set a value to a variable that biases the gate of a transistor for some time in transient simulation and then after particular time, I want that this variable should change to another value. Is this possible ?? For example- I am running a transient simulation for 15us. Until first 5 us, I want gate of transistor, g = 2 V, then this variable should change to g = 3 V at 10u. Also again it can be changeable at a particular time. Is this possible ??
Thanks in advance.
    1. PWL sources in spectre do not have a limit of 50 points; that's just a limitation of the analogLib vsource/vpwl component because of the practicalities of how it is implemented. If on the vsource you choose to take the points from a file, or you use vpwlf, then the number of points is unlimited. I don't know what you mean by "is there any alternate where I can just simply... in an instance".
    2. Yes, this can be done. Use the "Dynamic Parameter" checkbox on the tran analysis form in ADE and then you can specify piece-wise values for changing parameters. Note that the change is instantaneous though, so you might want to set (for example) time=0, value=2; time=10u, value=2; time=10.1u, value=3 - and then in the tran options form, in the Misc tab, in the additionalParams enter param_step=10n - which means it will update more smoothly by changing by 0.1V every 10ns over the while 100ns of the transition.
  • Charanraj Mohan
    Thanks Andrew.
    Seems am unfortunate to use 'Dynamic Parameter', as I am using ELDO simulator, where I don't have this option. Is there any other alternate for this ?
    Given that Eldo is a simulator from Mentor (A Siemens Business), this is not really the right forum to ask about capabilities of a simulator from a different EDA company.
    It also does tend to help if you mention which tools and versions you're using (as outlined in the Forum Guidelines) so that nobody tells you answers for tools you're not using.
    Of course, one alternative would be to switch to a simulator from Cadence such as Spectre which supports this ;-)
  • Charanraj Mohan
    Thanks Andrew
