  2. Mixed-Signal Design
  3. Error with the Connect Rules File
  • Subscribers 64
  • Views 16541
UniCam
UniCam over 9 years ago
Hi.
I'm running a simulation on a schematic including a functional block (Verilog). I have created my own Connect Rule files. The log file gives me the following error
ncelab: *E,NOUNIT: Unable to find a unit named 'myconnectLib.ConnRules_1V0_full_fast:connect' in the libraries.
I have added the myconnectLib in the cds.lib file and it does appear in the library manager.
I'm using IC6.1.7.
Best,
Mojtaba
    There are probably quite a few things you could have done wrong here - and asking all the questions to narrow down the problem is going to take more time than I have (I'm just back from vacation) so I would suggest contacting customer support is the right thing to do.
