  2. Mixed-Signal Design
  3. Conditional Expression in Design Variable in AMS
  • Subscribers 64
  • Views 20998
twen
twen over 8 years ago
This is a really simple test case to  show the issue with the conditional expression in a design variable in AMS. The pure Spectre simulator works fine with the conditional expression in a design variable and I can simulate with Spectre without any problem. However, when I switch the simulator into AMS, the AMS Unified Netlister with irun complains:
1/(X==1?1:6)
SYNTAX ERROR found at line 1 column 8 of file *string*
*Error* lineread/read: syntax error encountered in input
<<< Stack Trace >>>
(... in _amsaWriteDesignVariablesInfoToFile ...)
(... in _amsaGenCdsGlobals ...)
(... in _amsaCreateCdsGlobals (ams_session) ...)
_amsaCreateCdsGlobals(stdobj@0x3ebc83c8)
(... in asiApply ...)
(... in asiExecuteFlowchartStep ...)
(... in asiExecuteFlowchart ...)
(... in asiGenerateNetlist (asiAnalog_session) ...)
(... in asiRecreateNetlist (ams_session) ...)
funobj:asiRecreateNetlist(stdobj@0x3ebc83c8)
(... in _sevNetlistFile ...)
(... in sevNetlistFile ...)
sevNetlistFile(sevSession16 recreate)
Here is Virtuoso version:
"@(#)$CDS: virtuoso version ICADV12.3-64b 06/01/2017 15:59 (sjfhw311) $"
Here is the Spectre netlist so that I do not need to upload the schematic (the circuit does not matter in this test  case) and ADE settings:
// Generated for: spectre
// Generated on: Sep 28 10:30:13 2017
// Design library name: mylib
// Design cell name: conditiondesvar
// Design view name: config
simulator lang=spectre
global 0
parameters X=6 R=1/(X==1?1:6)
include "/models/toplevel.scs" section=tt
// Library name: mylib
// Cell name: conditiondesvar
// View name: schematic
// Inherited view list: spectre spice pspice verilog verilogams behavioral
// functional systemVerilog schematic veriloga vhdl vhdlams wreal
V0 (net2 0) vsource dc=1 type=dc
R0 (net2 0) resistor r=R
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
checklimitdest=psf
tran tran stop=10n write="spectre.ic" writefinal="spectre.fc" \
annotate=status maxiters=5
save R0:1
If I insert spaces around the '?' in the conditional expression, the AMS netlist succeeds, however the simulation fails with:
irun(64): 15.10-s002: (c) Copyright 1995-2015 Cadence Design Systems, Inc.
Fatal error found by spectre during hierarchy flattening.
FATAL (SFE-1996):
"/simulation/conditiondesvar/ams/config/netlist/cds_globals.vams"
25: Parameter `R': Attempt to divide by zero (1 / 0).
Here is the AMS netlist:
// PLEASE DO NOT EDIT OR COMPILE THIS FILE.
// IT IS MEANT FOR VIEWING PURPOSE ONLY.
// All files for configuration: (mylib conditiondesvar config)
// AMS netlist generated by the AMS Unified netlister
// IC subversion: ICADV12.3-64b.500.12
// IUS version: 15.10-s002
// Copyright(C) 2005-2009, Cadence Design Systems, Inc
// User: twen Pid: 7577
// Solver: Spectre
`include "disciplines.vams"
`include "userDisciplines.vams"
// Library - mylib, Cell - conditiondesvar, View - schematic
// LAST TIME SAVED: Sep 28 10:18:29 2017
// NETLIST TIME: Sep 28 10:44:54 2017
`worklib mylib
`view schematic
`timescale 1ns / 1ns
(* cds_ams_schematic *)
module conditiondesvar ( );
vsource #(.dc(1), .type("dc")) V0 (net2, cds_globals.\gnd! );
resistor #(.r(cds_globals.R)) R0 (net2, cds_globals.\gnd! );
endmodule
`noworklib
`noview
// Verilog-AMS cds_globals module for top-level cell:
// mylib/conditiondesvar.
// Generated by ADE.
// Cadence Design Systems, Inc.
// This is an autoGenerated file, any changes done to this file may get lost.
module cds_globals;
// Global Signals
electrical \gnd! ;
ground \gnd! ;
// Design Variables
dynamicparam real X = 6;
dynamicparam real R = 1/(X==1 ? 1:6);
endmodule
// This is the Cadence AMS Designer(R) analog simulation control file.
// It specifies the options and analyses for the Spectre analog solver.
global 0
simulatorOptions options temp=27 tnom=27 scale=1.0 scalem=1.0 reltol=1e-3 \
vabstol=1e-6 iabstol=1e-12 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
digits=5 pivrel=1e-3 checklimitdest=psf
wave_out options rawfmt=sst2
// Generated 'ie' card statement for the Connect Rules.
// TIME : Sep 28 10:44:56 2017
amsd{
ie vsup=1.8 discipline=logic
# This is the NC-SIM(R) probe command file
# used in the AMS-ADE integration.
# Database settings
if { [info exists ::env(AMS_RESULTS_DIR) ] } { set AMS_RESULTS_DIR $env(AMS_RESULTS_DIR)} else {set AMS_RESULTS_DIR "../psf"}
database -open ams_database -into ${AMS_RESULTS_DIR} -default
# Probe settings
probe -create -emptyok -database ams_database -flow {conditiondesvar.R0.1}
I can remove the conditional expression in the design variable and hard code R to a known value every time I run AMS. The problem is that I am trying to AMS simulate large design with more complex design variables created by other designers initially in Spectre env and it is really annoying with the little road blocks such as this one when transitioning to the AMS simulator.
TJ
    TJ, there appear to be two problems here - one in the netlisting, and one in the simulator (it appears to be dividing by the result of the comparison not the ternary result although I may be wrong). I've filed a CCR, 1825698, because I couldn't find one already. However, to track it properly and to give it customer emphasis you should contact customer support and request a duplicate CCR to be filed.
  • twen
    Cases #46209575 was created for the netlister by ADE-XL.
    Cases #46209580 was created for the simulator Spectre-APS.
    This is a relevant solution in IC 6.1.6. The solution says it is fixed in IC 6.1.7 ISR1. It re-appears in newer products.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXT2EAM&pageName=ArticleContent&sq=005d0000006EnYAAA0__20171019093043592
    TJ
    Actually that solution is related to the fact that ADE XL Global Variables are SKILL expressions whereas Design Variables (i.e. Test variables in ADE XL or Design Variables in ADE L) are AEL expressions (and passed directly to the simulator). SKILL doesn't have a ternary operator. So that's a different problem - this is specifically an issue where the generation of the cds_globals module in the AMS UNL netlister can't handle ternary expressions (without the space in). With the spaces in, something is wrong in the simulator itself.
