  2. Mixed-Signal Design
  3. Simulation CPU cores usage
  • Subscribers 64
  • Views 23518
AllenD
AllenD over 8 years ago
Hi Friends,
Can I please ask a question concerning simulation CPU cores usage.
When I was using ADS on a Windows PC for simulation, the software will automatically use all the cores and the CPU usage is close to 95%.
However, now I am using CADENCE IC 617 and MMSIM151 on a Linux machine with 10 cores CPU (20 threads). The simulation setup is like this:
ADE L --> Setup --> High-Performance Simulation Options. Then I click APS. choose Error Preset: DO not override; Use ++aps; Multi_Threading Manual #Threads: 20  (0-19)
But when I try to simulate, the CPU usage is about 40%. Though this is way better when I chose Spectre instead of APS to simulate(that's 5% CPU usage, due to only one thread is working.)
Can anyone help me? How can I setup the software to use all the CPU power to speed up the simulation?
Allen.
    Allen,
    How big is your circuit? Perhaps you can post the "Circuit Inventory" section of the log file. It has to be pretty large (probably hundreds of thousands of devices) to benefit from that number of cores. There's something known as Amdahl's Law which is quite useful to understand here - adding more parallel resource does not necessarily mean you speed up because there are some things that cannot be parallelised or the cost of managing the threads exceeds the benefit gained.
  • AllenD
    Thanks for your reply. Here is the Circuit Inventory log
    Circuit inventory:
    nodes 2165
    bsim4 277
    bsource_6c11d4 2
    capacitor 886
    diode 1108
    inductor 2
    isource 12
    relay 68
    resistor 1677
    vsource 74
    The circuit I am simulating now is just a part of my entire system. I would expect the number of the transistor will double in the future sim.
    I am running a transient simulation for a certain period of time. It often cost quite a long time for each run. That's why I was wondering if I can utilize all the calculation power from the CPU to speed it up. Do you have any recommendations? Anything can be helpful!
    Allen
    OK, that's pretty small. I wouldn't expect much benefit beyond 8 CPUs (in fact the benefit then is probably tailing off). The best option is to look at your accuracy settings - have you set errpreset tighter than you need to, for example. Often using +diagnose (this is on the Setup->Environment forms in recent IC617 versions, but if not you can type in +diagnose in the userCmdLineOption field on Setup->Environment). This can give some suggestions as to what (if anything) is limiting the performance.
    If that doesn't get you anywhere, I'd suggest contacting customer support. It may be that you cannot get it to go any faster - sometimes long simulations will indeed take a long time!
