  2. Mixed-Signal Design
  3. irun elaboration issue: vhdl package with relative path...
  • Subscribers 64
  • Views 16376
irun elaboration issue: vhdl package with relative path not found
dani0815
dani0815 over 8 years ago
hi all
I am simulation a mixed signal design with Virtuoso (ADE L, ams), which includes some custom vhdl packages. Vhdl file of that package has a 'package' view.
The issue is, that 'irun' links the package files with a relative path, and results in an error that the files cannot be found.
IC6.1.7-64b.500.10
irun(64) 15.20-s022:
short snapshot from irun command:
> irun -many -other -options -f /absolutePath/netlist/vhdlPkgTextInputs
and the file 'vhdlPkgTextInputs' content is:
-makelib  LIBRARY_NAME   ../../util_pkg.vhdl   -endlib
And the error message is:
irun: *E,FILEMIS: Cannot find the provided file ../../util_pkg.vhdl
When I edit the irun command file manually and change to absolute path, and then start from the command line, the netlisting of the design works ok.
Is there a hidden option in the gui to switch to absolute paths? Or any other suggestions? For the moment, I did not find a way to start the simulation ...
I hope the problem is understandable, I am happy to give more info. Thanks for any help in advance
Kind Regards
Dani
