  2. Mixed-Signal Design
  3. Compliance current setting in a voltage source.
  • Subscribers 64
  • Views 18399
Charanraj Mohan
Charanraj Mohan over 8 years ago
  I am doing some experiments on-chip using semiconductor analyser, where I can set a compliance current in the voltage source. Now I need to simulate a similar circuit. So, I need a voltage source where I should set compliance current in it. Is this possible in simulation ???
Thanks in advance
    The built-in voltage source doesn't have a compliance current (it would effectively need a non-zero output impedance to do this). That would require an enhancement request. You might be able to build a current limiter with VerilogA to achieve the same thing (I didn't try doing this by the way).
  • Charanraj Mohan
    Yes, Verilog-A is another option, which I tried. Thanks
