  2. Mixed-Signal Design
  3. verilog-A file simulation value update to the design variable...
  • Subscribers 64
  • Views 15493
verilog-A file simulation value update to the design variable in ADE-L
Charanraj Mohan
Charanraj Mohan over 8 years ago
Hey,
  I am using few iterations using the verilog-A file in spectre simulation. I have a design variable in ADE-L for a voltage pulse source written using pwlfile. I want that if my iteration in the code in verilog-A file succeeds my condition, the value I want should be used for a variable in the ADE-L. Is this possible ?
Thanks in advance
    Your question isn't that clear. Are you saying that you want your Verilog-A to calculate a value and then use that as a design variable in a subsequent simulation? If so, this can be done using ADE XL using calcVal to pass a measured output from one test to another - but before explaining that in more detail, I'd like you to clarify your question in case I've completely misinterpreted what you're asking...
