  2. Mixed-Signal Design
  3. BER simulation
  • Subscribers 64
  • Views 17285
BER simulation
Marjan
Marjan over 8 years ago
Hi Everyone,
Does anyone know how to do BER simulation or estimation in Cadence?
Thank you
    What kind of circuit is it that you want to measure the Bit Error Rate?
  • Marjan
    Marjan over 8 years ago in reply to Andrew Beckett
    Hi Andrew. Thank you for the reply. It is let's say for a circuit designed for a receiver. starts with the analog signal and end with a sense amplifier and latches with full rail signal output. Let me know if my explanation is clear.
    Andrew Beckett over 8 years ago in reply to Marjan
    Not sure I can answer this the. The support I was thinking of is via our wireless analysis (for various wireless standards) - and then it's for PAs and transmitter mixers.
    Probably the best thing to do would be to contact customer support so that you can discuss this in more detail with an application engineer; I'm not sure I can answer a fairly general question such as this myself.
