  2. Mixed-Signal Design
  3. pass ncsim commands through irun
  • Subscribers 64
  • Views 19236
albas
albas over 8 years ago
Hi all,
I'm trying to pass some extra commands to the ncsim console via irun commandline. Is this possible?
A typical use case is to disable assertions. In the console we can simply write "assertion -off -all" and disable all assertions. I would like to be able to do that through the command line.
Thanks a lot,
Al
    Put the Tcl commands in a file, and then run "irun -input commands.tcl".
  • albas
    albas over 8 years ago in reply to Andrew Beckett
    Hi, yes this is certainly an option, but then I need to maintain the file name, location and what not.
    Any alternatives?
    Andrew Beckett over 8 years ago in reply to albas
    Ah, sorry. Didn't realise you wanted to give the tcl command directly on the command line. You can use -input but start the next argument with @. So for example:
    irun -input "@assertion -off -all"
    You can give multiple statements, either by separating the commands with semi-colon or by giving multiple -input commands. For more details see this article (or search in INCISIVEinstDir/tools/bin/cdnshelp for "-input").
  • albas
    Hello Andrew, thanks a lot for the input. Indeed it works... but unfortunately it causes an issue in the connect phases of one of the uvm agents. I haven't investigated yet since the agent is an external IP and is difficult for us to modify it, so there's a discussion with the IP vendor as well.
    In the meantime, do you think I can inject the tcl command only after a certain phase of the simulation?
    If there is, I don't know how to do this (without spending some time hunting - maybe there is). Probably more of a Functional Verification question than mixed-signal. I suggest you contact customer support.
