  2. Mixed-Signal Design
  3. Problem in applying built-in Connect Rule
  • Subscribers 64
  • Views 16420
HANNN
HANNN over 8 years ago
Hi. This is my first time in mixed-signal simulation.
I was trying to apply connect rule.
And I got this error. MESSAGE: xdlib_openPakLib: failed to seek end of bfp of library 'connectLib'
I attatch full log file below.
Fullscreen simulation.log Download
ncvlog: 08.20-p001: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
file: /home/kkh4969/simulation/MCA/2x2MCA/adexl/results/data/Interactive.3/1/MCA:2x2MCA:1/netlist/ihnl/MCA/cds_globals/2x2MCA_config/verilog.vams
	module MCA.cds_globals:2x2MCA_config
		errors: 0, warnings: 0
ncvlog: Memory Usage - 8.6M program + 8.3M data = 16.9M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 60.7% cpu)
Successfully compiled ('MCA' 'cds_globals' '2x2MCA_config').
	module MCA.cds_globals:2x2MCA_config (up-to-date)
ncvlog: Memory Usage - 8.6M program + 8.1M data = 16.7M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 100.0% cpu)
file: /home/kkh4969/65nm/affirma_ams/etc/connect_lib/connectLib/ConnRules_18V_basic/connect/verilog.vams
ncvlog: *F,INTERR: INTERNAL ERROR
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL:	ncvlog	08.20-p001
  HOSTNAME: vlsi12
  OPERATING SYSTEM: Linux 2.6.18-194.el5 #1 SMP Fri Apr 2 14:58:14 EDT 2010 x86_64
ncvlog: Memory Usage - 8.6M program + 8.0M data = 16.6M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.1s, 11.5% cpu)
Failed to compile ('connectLib' 'ConnRules_18V_full_fast' 'connect').
file: /home/kkh4969/65nm/affirma_ams/etc/connect_lib/connectLib/ER_bidir/module/verilog.vams
  HOSTNAME: vlsi12
ncvlog: Memory Usage - 8.6M program + 8.2M data = 16.8M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 79.6% cpu)
Failed to compile ('connectLib' 'ER_bidir' 'module').
file: /home/kkh4969/65nm/affirma_ams/etc/connect_lib/connectLib/E2R/module/verilog.vams
  HOSTNAME: vlsi12
ncvlog: Memory Usage - 8.6M program + 8.1M data = 16.8M total
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 94.2% cpu)
Failed to compile ('connectLib' 'E2R' 'module').
file: /home/kkh4969/65nm/affirma_ams/etc/connect_lib/connectLib/Bidir_2/module/verilog.vams
  HOSTNAME: vlsi12
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 84.5% cpu)
Failed to compile ('connectLib' 'Bidir_2' 'module').
file: /home/kkh4969/65nm/affirma_ams/etc/connect_lib/connectLib/E2L_2/module/verilog.vams
  HOSTNAME: vlsi12
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 82.7% cpu)
Failed to compile ('connectLib' 'E2L_2' 'module').
file: /home/kkh4969/65nm/affirma_ams/etc/connect_lib/connectLib/L2E_2/module/verilog.vams
  HOSTNAME: vlsi12
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 79.9% cpu)
Failed to compile ('connectLib' 'L2E_2' 'module').
file: /home/kkh4969/65nm/MCA/row_switch/verilogams/verilog.vams
	module MCA.row_switch:verilogams
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.1s, 9.1% cpu)
Successfully compiled ('MCA' 'row_switch' 'verilogams').
file: /home/kkh4969/simulation/MCA/2x2MCA/adexl/results/data/Interactive.3/1/MCA:2x2MCA:1/netlist/ihnl/MCA/memristor/veriloga/verilog.vams
	module MCA.memristor:veriloga (up-to-date)
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 58.6% cpu)
Successfully compiled ('MCA' 'memristor' 'veriloga').
file: /home/kkh4969/simulation/MCA/2x2MCA/adexl/results/data/Interactive.3/1/MCA:2x2MCA:1/netlist/ihnl/MCA/2x2MCA/schematic/verilog.vams
	module MCA.2x2MCA:schematic
ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 30.7% cpu)
Successfully compiled ('MCA' '2x2MCA' 'schematic').
Compilation failed.
Successfully compiled: 5
Failed to compile: 6
Thank you
    First of all, you’re using an ancient version of the simulator - why are you using something that is probably getting on for 10 years old?
    There’s an article on this error on support.cadence.com - article 11361194 - can’t easily add the link as I’m replying from my phone. The cause is usually that the .pak file in the root of the library (connectLib) is zero-sized for some reason. You may need to delete it.
