  2. Mixed-Signal Design
  3. unable to simulate this veriloga code in cadence
  • Subscribers 64
  • Views 14797
noob1
noob1 over 7 years ago
To the respected form members I am noob to this I have a Veriloga code with me but I am facing parsing error with it The code is genuine and i want to know where it get wrong thank you.
code:
https://drive.google.com/open?id=0BxdIdGj7u4DWeTdQUUlpOW5ZUUJpLWRKaTRPSGRLemVTZjNN
this is the google link for the
    First you should read the Forum Guidelines. You didn't say where you were getting these parser errors (which tools, which versions) or what the errors are.
    I tried reading the file in spectre. There are two issues:
    1. The file has strange line endings. Normally on Windows you'd have "CRLF" (carriage return+line feed) or on Linux you'd have "LF" (line feed only). This has Carriage return only - and that seems to trouble the spectre parser (it troubles lots of things to be honest). I fixed that by doing (in Linux):
        mv ucsb_2dfet.va ucsb_2dfet_orig.va
        cat ucsb_2dfet_orig.va | tr '\r' '\n' > ucsb_2dfet.va
    2. Then it fails with this:
      Error found by spectre during AHDL read-in.
        ERROR (VACOMP-2259): "modulel<<--? tmdfet(S,D,Gt,Gb); "
          "ucsb_2dfet.va", line 5: syntax error.
        ERROR (VACOMP-1814): Maximum allowable errors exceeded. Exiting AHDL
          compilation....
      That's because at the beginning it starts with "modulel" and it should be "module". If I fix that, all is OK (well, it compiles and simulates - I can't vouch for whether the model works OK or not).
  • noob1
    noob1 over 7 years ago in reply to Andrew Beckett
    Thanks sir,
    You are right about the EOL . IT has been helpful.
    Hafi.
