  2. Mixed-Signal Design
  3. eye diagram problem
  • Subscribers 64
  • Views 17950
eye diagram problem
ManuelSuarez
ManuelSuarez over 8 years ago
Hi everybody,
I am suffering problems with the eye diagram in cadence.  By an unknown reason, it does not update the results.
I explain the case:
I simulate a relatively complex circuit with different outputs but, let me say i am interested in the output Out0 to simplify. When i generate the eye diagram the first time it is ok but, when i run a new simulation after modify some parameter the eye diagram is the same even when i can see clearly that the waveforms are different. Seems that for different simulations of the Out0, the eye diagram tool keeps linked to the values of the first simulation.
I have to restart cadence brake this link and get the correct eye diagram.
I use virtuoso IC6.1.6-64b.500.13.2
Some explanation for this interesting behavior?
Thanks in advance,
M
    Not really enough information - how are you running the simulation? Is the eye diagram added as an output in ADE L/XL (if so which) or are  you generating it once and then updating it somehow? If so how?
    I think a more detailed description of how you get from A to B is needed here to understand the problem.
  • ManuelSuarez
    ManuelSuarez over 8 years ago in reply to Andrew Beckett
    Thanks for the quick answer.
    I use the analog design environment to design the digital circuits I need. I run the transient analysis of the ADE using spectre APS.  Later I plot the results through the virtuoso visualization and analysis XL. Ones the results are plotted I select the squared waveform I need. In the upper menu of the window of the Virtuoso visualization and analysis XL: Measurements>EyeDiagram.
    A window pops up and I fill the values. For the first simulation is fine.
    I always follow the same procedure:
    1-Simulation>plot signals>select signal>eye diagram(as mentioned)
    2-Circuit modification
    3-Again simulation>plot signals>select signal>eye diagram
    4-...
    Furthermore, i run a parametric simulation (two values) following the previous procedure and I get the eye diagram with as many eyes as parametric steps, that is fine. After i run a single non parametric simulation and the eye diagram corresponds to the parametric simulation.
    The problem persist when I close and reopen the ADE. I have to open and close cadence.
    I hope the information is sufficient now.
    M
