  2. Mixed-Signal Design
  3. Missing EEnet connect modules
  • Subscribers 65
  • Views 23635
drdanmc
drdanmc over 8 years ago
I have a systemVerilog real number model for an analog block.  There are some logic ports and several EEnet ports.  Next step was going to be to get dmv set up for model validation.  I have a top level schematic that has one instance of the block in question and one instance of a stimulus/measurement block.  For that test bench block I wrote a systemVerilog program that runs through all of the different control bits into the block.  This runs fine with ams within ADE-L.  Next, with the hierarchy editor, I picked the schematic view for my circuit block.  This won't simulate because of missing connect modules to provide the connection from EEnet to/from electrical.   I see what appears to be the correct connect module in
.../XCELIUM1704/tools.lnx86/affirma_ams/etc/connect_lib/EEnet_to_E_bidir.svams
but can't seem to figure out where I actually tell the elaborator to actually use this and so I get lots of:
xmelab: *E,CUVNCM (./netlist.vams,1098|30): No connection module found:Need inout ports of nettype EEnet with attribute logic, continuous discipline electrical, at instance MyTopCell.ITEST_BENCH.
So I have three questions
1)  how to actually get this connect module into the tool?
2) in that error message it says '... of nettype EEnet with attribute logic...".  What is the "with attribute logic" part?
3) is there a way to put in some `ifdef stuff to switch my systemVerilog test bench to use electrical when connecting to the schematic version and avoid needing connect modules that way?  What would be more typical?  I've done a modest amount with Verilog-AMS and wreal but not much with dmv or systemVerilog and EEnet.
IC617, XCELIUM1704
-Dan
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    Hi Dan,
    To answer your questions:
    1. You'll have to point to the file 'EEnet_to_E_bidir.svams' (with the full path) in your xrun command. This is just like including any *.v or *.sv in your simulation run on the command-line.
    2. 'attribute logic' refers to discrete domain which applies to real numbers being solved by digital solver.
    3. I think what you are suggesting will need 'electrical' domain in a *.sv file, right? This isn't supported. I think what you are proposing will work on the same lines as the connect modules in *.svams file but that format is still being worked upon. With the auto-insertion of EEnet-to-electrical connect modules, you won't need to use electrical discipline in the SV testbench.
    Saloni
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to Saloni Chhabra
    I must also add that auto-insertion of EEnet-to-electrical connect modules was introduced last year. Going forward, the user will not have to provide the path to the CM (*.svams) in the run command, but the version of Xcelium with this enhancement hasn't been finalized yet.
    Saloni
  • drdanmc
    drdanmc over 8 years ago in reply to Saloni Chhabra
    Thanks Saloni.  That was a big help.  #1 worked for me.  #2 ended up not being anything to worry about.
    Where would I go to read about svams as opposed to sv or vams?
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to drdanmc
    Hi Dan,
    That's great. Co-existence of SV and VAMS in the same code (.svams) is a new standard being developed and will take some time (years) to be formalized. Until then, you will have to rely on the insertion of connect modules if you must have EEnet interacting with electrical signals.
    Saloni
  • LViji
    LViji over 7 years ago in reply to Saloni Chhabra
    I am a new user of the EEnet type connection. I have come across a similar problem and after searching through the community I was able to solve the problem by adding the link as suggested. However I am now seeing a different issue.
    Basically I have a model as shown below.
    module current_bias (i_bias, en);
    output [9:0] i_bias;
    input en;
    EEnet i_bias [9:0];
    endmodule
    This block is instantiated in a top level schematic where I try to run an AMS simulation. This gives me an error as shown below
    current_bias I_curr_bias(.i_bias(i_bias[9:0]);
     xmelab: *E,CICAPC (./netlist.vams,1846|38): incompatible or unsupported array port connection.
    What could be the problem here?
    Viji
  • Frank Wiedmann
    Frank Wiedmann over 7 years ago in reply to LViji
    Take a look at Cadence Solution 20482796.
