  2. Mixed-Signal Design
  3. straight line (best) fit using viva calculator
  • Replies 18
  • Subscribers 67
  • Views 37333
vamshiky
vamshiky over 8 years ago
I need to measure peak to peak variation of phase response (from an AC sim) w.r.t a straight line fit(best fit and not the end point fit)  for the same.
Is it doable using viva calculator or verilogAMS ?
vamshiky
    Andrew Beckett over 8 years ago +1
    There's no built-in function to do this, and I'd not written one so far (it's been one of those things I've been meaning to for a while because I think it's come up in the past). So I just quickly wrote…
    There's no built-in function to do this, and I'd not written one so far (it's been one of those things I've been meaning to for a while because I think it's come up in the past). So I just quickly wrote this code below.
    To use it, save the code in a file called "abBestFit.ils" and load it from your .cdsinit using load("/path/to/abBestFit.ils") - ensure you keep the .ils suffix. Unfortunately you can't (yet) use the "fx" button in the calculator to register it with the calculator, so for now you'll need to just surround your waveform expression with abBestFit(...) and then  you can plot that.
    /* abBestFit.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 05, 2018
    Modified   Nov 22, 2023
    By         A.D.Beckett
    Compute a best fit line for an input waveform. Uses
    Simple Linear Regression to compute the slope and intercept
    and then constructs a waveform with this slope and intercept
    Four functions:
    abBestFit(waveform) - returns a best fit waveform
    abBestFitSlope(waveform) - returns the slope of the best fit line
    abBestFitIntercept(waveform) - returns the y intercept of the best fit line
    abBestFitCoeffs(waveform) - returns a list of the intercept and slope.
        Note: this function does not handle family waveforms because it
        returns a list - but is useful for single waveforms
    Note, this uses SKILL++ lexical scoping so must keep the .ils
    suffix
    From IC618 ISR1 can now be added to the calculator via the fx button
    (also in the expression builder via the + button)
    SCCS Info: @(#) abBestFit.ils 11/22/23.14:16:49 1.4
    (let ()
      *                        (mean vector)                         *
      *     Internal function to compute the mean of the values      *
      *                        in the vector                         *
      (defun mean (vector)
        (let ((n (drVectorLength vector)) (sum 0.0))
          (for i 0 (sub1 n)
               (setq sum (plus sum (drGetElem vector i))))
          (quotient sum (if (zerop n) 1 n))
      *            (uncorrectedStddev vector vectorMean)             *
      * Internal function to compute uncorrected standard deviation  *
      *  of vector. Same as population standard deviation. Pass in   *
      *   vector and mean so don't have to compute the mean again    *
      (defun uncorrectedStddev (vector vectorMean)
          (for i 0 (sub1 n)
               (setq sum
                     (plus sum
                           (expt
                             (difference (drGetElem vector i) vectorMean)
                             2))))
          (sqrt (quotient sum (if (zerop n) 1 n)))
      *            (sampleCorrCoeff xVec yVec xMean yMean)             *
      * Internal function to compute the sample correlation coefficent *
      *                  between the x and y vectors                   *
      (defun sampleCorrCoeff (xVec yVec xMean yMean)
        (let (xSquared ySquared xy xyMean xSquaredMean ySquaredMean)
          (setq xy (times xVec yVec))
          (setq xSquared (expt xVec 2.0))
          (setq ySquared (expt yVec 2.0))
          (setq xyMean (mean xy))
          (setq xSquaredMean (mean xSquared))
          (setq ySquaredMean (mean ySquared))
          (quotient
            (difference xyMean (times xMean yMean))
            (sqrt
              (times
                (difference xSquaredMean (expt xMean 2.0))
                (difference ySquaredMean (expt yMean 2.0))
      *                  (computeCoeffs xVec yVec)                   *
      *  Internal function to compute the alpha and beta - intercept *
      *             and slope - from the x and y vectors             *
      (defun computeCoeffs (xVec yVec)
        (let (xMean yMean xStddev yStddev rxy alpha beta)
          (setq xMean (mean xVec))
          (setq yMean (mean yVec))
          (setq xStddev (uncorrectedStddev xVec xMean))
          (setq yStddev (uncorrectedStddev yVec yMean))
          (setq rxy (sampleCorrCoeff xVec yVec xMean yMean))
          (setq beta (times rxy (quotient yStddev xStddev)))
          (setq alpha (difference yMean (times beta xMean)))
          (list alpha beta)
      *                    (abBestFitCoeffs wave)                    *
      *  Global function to compute alpha and beta - intercept and   *
      *          slope of the best fit line and return them          *
      (defglobalfun abBestFitCoeffs (wave)
        (let (xVec yVec)
          (setq xVec (drGetWaveformXVec wave))
          (setq yVec (drGetWaveformYVec wave))
          (when (eq (drGetWaveformYType wave) 'doublecomplex)
            (error "abBestFitCoeffs: Cannot handle waveforms with complex values; use mag() or db20() or similar to convert to double values")
      *                       (abBestFit wave)                       *
      *           Compute the slope and intercept and then           *
      *  create a waveform (with two points) matching the first and  *
      *             last x points of the input waveform              *
      (defglobalfun abBestFit (wave)
        (cond
          ((drIsWaveform wave)
           (let (xVec yVec len firstX lastX newXVec newYVec newWave)
             ; Compute slope and intercept of best fit line
               (error "abBestFit: Cannot handle waveforms with complex values; use mag() or db20() or similar to convert to double values")
             (destructuringBind (alpha beta) (computeCoeffs xVec yVec)
               ; Construct best fit line waveform
               (setq len (drVectorLength xVec))
               (setq firstX (drGetElem xVec 0))
               (setq lastX (drGetElem xVec (sub1 len)))
               (setq newXVec (drCreateVec 'double 2))
               (setq newYVec (drCreateVec 'double 2))
               (drAddElem newXVec firstX)
               (drAddElem newXVec lastX)
               (drAddElem newYVec (plus alpha (times beta firstX)))
               (drAddElem newYVec (plus alpha (times beta lastX)))
               ; Sort out attributes for new waveform to match input
               (putpropq newXVec (getq xVec units) units)
               (putpropq newXVec (getq xVec name) name)
               (putpropq newYVec (getq yVec units) units)
               (putpropq newYVec (getq yVec name) name)
               (setq newWave (drCreateWaveform newXVec newYVec))
               (famSetExpr newWave `(abBestFit ,(famGetExpr wave)))
               newWave
          ((famIsFamily wave)
           (famMap 'abBestFit wave)
          (t
            (error "abBestFit: cannot handle %L\n" wave)
      *                      (abBestFitSlope wave)                       *
      * Compute the slope (beta) of the best fit through a set of points *
      (defglobalfun abBestFitSlope (wave)
        (cond
           (cadr (abBestFitCoeffs wave))
          ((famIsFamily wave)
           (famMap 'abBestFitSlope wave)
          (t
            (error "abBestFitSlope: cannot handle %L\n" wave)
      *                       (abBestFitIntercept wave)                       *
      * Compute the intercept (alpha) of the best fit through a set of points *
      (defglobalfun abBestFitIntercept (wave)
        (cond
           (car (abBestFitCoeffs wave))
          ((famIsFamily wave)
           (famMap 'abBestFitIntercept wave)
          (t
            (error "abBestFitIntercept: cannot handle %L\n" wave)
    ;;;;;;;;;;;;;;;;;;;;;;;;;; GUI builder information ;;;;;;;;;;;;;;;;;;;;;;;;;;;
    ocnmRegGUIBuilder(
     '(nil
      function abBestFit
      name abBestFit
      description "Best Fit Line"
      category ("Custom Functions")
      analysis (nil
          general (nil
            args (wave )
              signals (nil
                    wave (nil
                          prompt "Signal"
                          tooltip "Waveform"
              params(nil
            inputrange t
      outputs(result)
    ocnmRegGUIBuilder(
     '(nil
      function abBestFitIntercept
      name abBestFitIntercept
      description "abBestFitIntercept"
      analysis (nil
          general (nil
            args (wave )
              signals (nil
                    wave (nil
                          prompt "Signal"
                          tooltip "Waveform"
              params(nil
            inputrange t
      outputs(result)
    ocnmRegGUIBuilder(
     '(nil
      function abBestFitSlope
      name abBestFitSlope
      description "abBestFitSlope"
      analysis (nil
          general (nil
            args (wave )
              signals (nil
                    wave (nil
                          prompt "Signal"
                          tooltip "Waveform"
              params(nil
            inputrange t
      outputs(result)
  • vamshiky
    vamshiky over 8 years ago in reply to Andrew Beckett
    Thanks for the quick response Andrew, I shall try and get back.
  • zeloufi
    zeloufi over 8 years ago in reply to Andrew Beckett
    Hello Andrew
    I use positively this function and it is great !
    Thank you very much !
  • vamshiky
    vamshiky over 8 years ago in reply to vamshiky
    Thanks this was very useful, cross checked with matlab as well.
  • acrasso
    acrasso over 8 years ago in reply to Andrew Beckett
    Thank you for this post.  I have two questions related to this code.
    First, when  I use abBestFitCoeffs in the calculator I get an answer that says for example complex( 1, 2 ).  When I enter that into output setups as an expression it gives me an eval error.  I am guessing Explorer has trouble outputting the complex number?  In the calculator I can separate the numbers by doing real and imag on the value returned.  But again when I try to add that in as an expression the tool says that it says Error* real: can't handle real((1 2)).  Any hints on how to output a signal value for each the slope and the intersect when writing it in as an expression? Sorry if I am missing something basic.
    Second, anyway to expand this to higher orders easily?
    Anthony
    Andrew Beckett over 8 years ago in reply to acrasso
    Hi Anthony,
    The abBestFitCoeffs function isn't really intended to be used in the calculator. It returns a list of two numbers (the slope and the intercept), and the calculator and ADE outputs aren't really designed to receive a list. Rather oddly, the calculator converts the list of two values into a complex number (I wasn't expecting it to do that) - so instead if you need to retrieve the coefficients, I suggest you use:
    car(abBestFitCoeffs(wave))
    or
    cadr(abBestFitCoeffs(wave))
    as then you'll get a single number from each.
    Of course, you could write code to do a higher order polynomial fit, but that's more work (it's not just a trivial change to the code). You'd probably have to read up on how to do it...
  • vamshiky
    I was wondering if we can get end point fit with the same code.. probably with some minor modifications.
    vamshiky
    Andrew Beckett over 8 years ago in reply to vamshiky
    So you just want a line between the first and last points? That would be very easy (although it wouldn't need any of the existing best fit code because it's much simpler). Before I show you how, I want to make sure I've understood that this is what you meant...
  • vamshiky
    Yes I want a line between first and last points, so that I can find the deviation from this fitted straight line.
    I wouldn't call it a fitted line, but here's the code nevertheless. Was quite easy to throw together (it does bear some similarities with abBestFit, but it's considerably simpler as it doesn't need to do any linear regression).
    /* abFirstLastLine.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 16, 2018
    Modified
    By
    Construct a line between first and last points in waveform.
    Not a best fit - just a simple line consisting of just the first
    and last points.
    Includes function template so this can be added to the calculator
    with the "fx" button in the calculator function panel.
    SCCS Info: @(#) abFirstLastLine.il 05/16/18.22:55:10 1.1
    *                       (abFirstLastLine wave)                       *
    * Output a waveform which just contains the first and last points of *
    *                        the input waveform.                         *
    (defun abFirstLastLine (wave)
      (cond
         (let (xVec yVec newXVec newYVec len newWave)
           (drAddElem newXVec (drGetElem xVec 0))
           (drAddElem newXVec (drGetElem xVec (sub1 len)))
           (drAddElem newYVec (drGetElem yVec 0))
           (drAddElem newYVec (drGetElem yVec (sub1 len)))
           (famSetExpr newWave `(abFirstLastLine ,(famGetExpr wave)))
           newWave
        ((famIsFamily wave)
         (famMap 'abFirstLastLine wave)
        (t
          (error "abFirstLastLine: cannot handle %L\n" wave)
    ocnmRegGUIBuilder(
     '(nil
      function abFirstLastLine
      name abFirstLastLine
      description "Create line between first and last points"
      analysis (nil
          general (nil
            args (wave )
              signals (nil
                    wave (nil
                          prompt "Waveform"
                          tooltip "Waveform"
              params(nil
            inputrange t
      outputs(result)
