  2. Mixed-Signal Design
  3. ModGen and Common Centroid Layout
  • Subscribers 65
  • Views 20042
growingmind
growingmind over 8 years ago
I am trying to use ModGen to do Common Centroid Layout in CMOS using ModGen and Contraint Manager.
Is there a tutorial/RAK about this ?  I am getting some errors and wondering if they are kit related.
The errors are mostly about symmetry - and Cadence complains the structure it has synthesized is not symmetric.
In any case, thank you.
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
     Not sure how you do Common Centroid on your Modgen. You can use the "Common Centroid" Pattern Preset which is available in the Grid Pattern Editor Assistant in the Modgen Editor.
     There is this RAK Modgen on Canvas available which you can use as example.
    Hope it helps.
    Dimitra
