  2. Mixed-Signal Design
  3. Not fitting lmax-lmin, wmax-wmin or areamax-areamin ran...
  • Subscribers 64
  • Views 24189
Not fitting lmax-lmin, wmax-wmin or areamax-areamin range
Nicolas Callens
Nicolas Callens over 8 years ago
During transient simulation of my circuit in IC6.1.7 I've encountered some problems in terms of not giving the correct dimensions in the max-min range for my transistors. However, this is strange since my dimensions are in the correct range specified by the input.scs file... Underneath you can find the ERROR (CMI-2440):
 ERROR (CMI-2440): "input.scs" 38: INTEGRATOR-1.pmos-switch-reset:  The length, width, or area of the instance does not fit the given lmax-lmin, wmax-wmin, or areamax-areamin range for any model in the `pch' group. The channel width is 2.000000e-07 and length is 6.500000e-08. Specify channel width and length that do not exceed the referenced maximal area Lmax=2.000001e-05, Lmin=6.000000e-08, Wmax=9.000000e-04 and Wmin=1.200000e-07. You can choose the nearest model by setting the value of `soft_bin' option to `allmodels'.
As you can see, my dimensions are in the specified range...
Thanks!
Kind regards,
Nicolas
    The message reports the extremes, but that doesn't mean there's a bin that fits. For example:
    model nch bsim4 {
    1: type=n \
    lmin=1e-6 lmax=10e-6 wmin=9e-6 wmax=10e-6
    2: type=n \
    lmin=1e-6 lmax=2e-6 wmin=1e-6 wmax=9e-6
    M3 (d g s s) nch w=2e-6 l=3e-6
    This will fail with a similar message - because whilst both w and l are in the range of the wmin-wmax and lmin-lmax, there's no single bin that that w/l combination fits in.
    So maybe it's that?
  • Nicolas Callens
    Nicolas Callens over 8 years ago in reply to Andrew Beckett
    Your explanation sounds logical, however, when I designed the same transistors with the same dimensions in another design I don't get such error...
    Kind regards,
    Nicolas
    Andrew Beckett over 8 years ago in reply to Nicolas Callens
    Hi Nicolas,
    Maybe it's a bug in the specific version of spectre you're using (seems a bit odd though), or maybe in the other design you had the option soft_bin set to models as the message says? Probably best to take this up with customer support so that we can take a look at the model, netlist and versions to investigate more closely.
  • Nicolas Callens
    When I wanted to change the simulator options regarding the model bins, I've found out that the scaling factor of my device was 1.0e-06 instead of 1.0. Very weird, especially because I have not been editing the Simulator Options Form... Though, everything seems the work with the correct scaling factor of 1.0.
    Thanks Andrew for the help!
    Kind regards,
    Nicolas
