  2. Mixed-Signal Design
  3. how to convert text string to integer in VerilogA?
  • Replies 12
  • Subscribers 64
  • Views 27792
DavidLou
DavidLou over 8 years ago
hello experts,
in VerilogA, "reg" is not supported in Cadence yet even it's described in the Cadence version of VerilogA manual, and I'm having a hard time to pass some text string into integer value (ideally into bit values). I can not access individual bit of a string type. seems wire [] array is type of node and therefore I can't use it in assignment. anyway, I'm seeking for someway to convert string like "Hello World" into integer (ascii) values.
thanks a lot,
David
    Andrew Beckett over 8 years ago in reply to DavidLou
    Hi David,
    OK, that's ISR9 (if you use Help->About it will show IC6.1.7-64b.500.9)
    There was a bug that awvCreateBus ignored the radix argument which was fixed in IC6.1.7-64b.500.12 - so a bit newer than the version you're using. I'm sure that's the reason why it works for me and not for you.
    Regards.
  • DavidLou
    DavidLou over 8 years ago in reply to Andrew Beckett
    haha, mystery solved then. thanks Andrew as always.
