  2. Mixed-Signal Design
  3. Schematic Extraction of Standard Cells of TSMC 40nm and...
  • Subscribers 64
  • Views 17220
Schematic Extraction of Standard Cells of TSMC 40nm and AMS
anurans
anurans over 8 years ago
Hi All,
I am working with tsmc 40nm pdk and would like to analyze their standard cell libraries (in schematic or layout) for mixed signal simulations (AMS). However, it appears that, the distributors do not provide cadence OA libraries for std cells nor transistor level netlists. When I import the relevant .lef files, only the abstract view of the layout is visible (metal 1 layer routes). The provided verilog netlist can only import symbol views of the cells.So under the given conditions, is performing AMS on this std cells in virtuoso not possible at all (atleast the schematic extraction)?
Thanks in advance
Anuradha
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    Hi Anuradha,
    If you create the symbols for std cells in a library, you can then point to the corresponding verilog files as a command-line argument to your AMS simulation. Here's a Rapid Adoption Kit on AMS flow:
    https://support.cadence.com/apex/articleattachmentportal?id=a1O0V000007MnZlUAK&pageName=ArticleContent&attachId=0690V000003xwUGQAY&sq=005d0000001T4VEAA0_201852211126632
    In this example, there is a cell called 'inv'. If you didn't have a verilog view for this cell, the config view will choose symbol as the stop view. When you run AMS simulation from ADE, you can provide the *.v files for standard cells.
    On the same lines, instead of providing *.v files to irun, you can use -makelib and  -reflib options. Using -makelib, you can compile all std cell *.v files once into a user-defined library. Then, in all subsequent simulations, you can point to this compiled library using -reflib argument. This method is well documented, but if you need any further help, please tell me the IC and INCISIVE version you are using so I can share the correct tool snapshots with you.
    Regards
    Saloni
