  2. Mixed-Signal Design
  3. table_model multi-column data file
  • Subscribers 64
  • Views 19357
olalivier
olalivier over 8 years ago
Hi there,
I try to write a model using table model, verilog-ams with wreal.
The file I want to use is a multi-column file with one x column (left most col) and several y columns. I would like to use this file and plot independantly all the y columns
vy1  = $table_model(vx, "../data/text.txt","I,1L");
vy2 = $table_model(vx, "../data/text.txt","I,I,1L");
vy3 = $table_model(vx, "../data/text.txt","I,I,I,1L");
and so on. My table looks like this
IPRB1 X IPRB1 Y IPRB2 X IPRB2 Y IPRB4 X IPRB4 Y IPRB3 X IPRB3 Y
0.000000000000000E+00 3.162096725343170E-11 0.000000000000000E+00 3.162096725343160E-11 0.000000000000000E+00 3.170924885575280E-11 0.000000000000000E+00 3.170924903331000E-11
4.800000000000000E-08 4.828014646421500E-09 4.800000000000000E-08 4.828014646421500E-09 4.800000000000000E-08 4.828078816122020E-09 4.800000000000000E-08 4.828078816124640E-09
9.600000000000000E-08 9.640872049559960E-09 9.600000000000000E-08 9.640872049544430E-09 9.600000000000000E-08 9.640903627434960E-09 9.600000000000000E-08 9.640903627403870E-09
1.440000000000000E-07 1.445212538412270E-08 1.440000000000000E-07 1.445212538412190E-08 1.440000000000000E-07 1.445213629970190E-08 1.440000000000000E-07 1.445213629971590E-08
1.920000000000000E-07 1.926229797216590E-08 1.920000000000000E-07 1.926229797215260E-08 1.920000000000000E-07 1.926229309238320E-08 1.920000000000000E-07 1.926229309242870E-08
2.400000000000000E-07 2.407161292687310E-08 2.400000000000000E-07 2.407161292686580E-08 2.400000000000000E-07 2.407159507634300E-08 2.400000000000000E-07 2.407159507636590E-08
2.880000000000000E-07 2.888025477141720E-08 2.880000000000000E-07 2.888025477140600E-08 2.880000000000000E-07 2.888022570966160E-08 2.880000000000000E-07 2.888022570964910E-08
3.360000000000000E-07 3.368832800711010E-08 3.360000000000000E-07 3.368832800710330E-08 3.360000000000000E-07 3.368828898044660E-08 3.360000000000000E-07 3.368828898046150E-08
3.840000000000000E-07 3.849590980009490E-08 3.840000000000000E-07 3.849590980009320E-08 3.840000000000000E-07 3.849586174022050E-08 3.840000000000000E-07 3.849586174022720E-08
4.320000000000000E-07 4.330305901536250E-08 4.320000000000000E-07 4.330305901536050E-08 4.320000000000000E-07 4.330300264738480E-08 4.320000000000000E-07 4.330300264739470E-08
Is it possible to do so ??
thank you very much for your help.
Olivier
    Andrew Beckett over 8 years ago +1
    Hi Olivier, This got put into moderation because the system saw the repeated text and assumed it was spam. I moved it out of moderation, and then moved it to this forum instead as it's more appropriate…
    Hi Olivier,
    This got put into moderation because the system saw the repeated text and assumed it was spam. I moved it out of moderation, and then moved it to this forum instead as it's more appropriate for mixed-signal modelling.
    I think what  you want is:
    vy1=$table_model(vx,"forum48.txt","1L;1");
    vy2=$table_model(vx,"forum48.txt","I,I,1L;1");
    vy3=$table_model(vx,"forum48.txt","I,I,I,I,1L;1");
    In the first case, you want the left most column as the independent variable, and then the next column after that as the dependent variable (the output). That's the ;1 bit which tells it that the first of the remaining columns is the dependent variable. For the subsequent outputs, you always want to ignore a pair of columns, and then use the odd columns as the independent variable, with the column straight after that as being the dependent variable.
    I tweaked the numbers in  your table just so I could test that it was behaving as I was expecting - seems to work OK this way (if I've understood your requirement). Of course, I'm expecting that vx is the independent variable you're trying to look up in the table. Here's what I used for testing:
    `include "disciplines.vams"
    module forum48(op,ip);
    output op;
    input ip;
    electrical op,ip;
    real vx,vy1,vy2,vy3;
    analog begin
      vx=V(ip);
      V(op) <+ vy1;
    end
    endmodule
    and then the netlist (I just tested with the above as a VerilogA model in forum48.va) with the netlist below as forum48.scs:
    vramp (ramp 0) vsource type=pulse rise=1u val0=0 val1=3e-7
    I1 (meas ramp) forum48
    ahdl_include "forum48.va"
    myopts options saveahdlvars=all
    tran tran stop=1u
  • olalivier
    olalivier over 8 years ago in reply to Andrew Beckett
    Dear Andrew,
    thank you very much for your answer. It works perfectly.
    If I may, I'd like to ask you another question related to table_model. Do you know what is the algorithm behind this function ? I would like to know if the table model loads the entire table once or if it access the file everytime I ask for it ? I ask this because my simulation time is quite long compared to transistor level (spectre) simulation... The design is small, around 30 transistors (65nm). schematic level takes around 200ms, verilog-wreal with table 4s...
    thank you for your answer.
    OL
    Andrew Beckett over 8 years ago in reply to olalivier
    I don't know, is the simple answer. I suspect it's not read at each time point and is smarter than that (even if it was, I suspect it wouldn't have such a big impact). More likely it's some convergence challenge caused by your model - I can't really say though.
    This is something that would be best handled through customer support so that it can be investigated more closely.
