  2. Mixed-Signal Design
  3. display analog signal voltage in VerilogAMS
  • Subscribers 65
  • Views 16638
DavidLou
DavidLou over 8 years ago
hello exports,
wonder if I can find some help here.
I want to display the analog signal's voltage at digital clock edge in VerilogAMS code. the compiler keeps telling me this hierarchical signal access is illegal. is there a way to achieve this? the hierarchy path is definitely right as it can compile if I remove "V()" although I don't get the right voltage answer.
                 ncelab: *E,ILLSARG (..../verilogams/verilog.vams,735|52): Illegal argument for signal access function [4.3(AMSLRM)].
module testbench
   always @(negedge clk ) begin
      $display("====  %g  ", V(top.sub.leaf) );
   end
   analog begin
   end
endmodule
regards,
David
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago
    Use $cgav (see https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000t4bIEAQ).
  • DavidLou
    DavidLou over 8 years ago in reply to Frank Wiedmann
    perfect, working great now. thanks Frank
