  2. Mixed-Signal Design
  3. Mixed IC Design Flow Using: Synopsys DC-ICC & Cadence V...
  • Subscribers 64
  • Views 1912
Mixed IC Design Flow Using: Synopsys DC-ICC & Cadence Virtuoso
maronline
maronline over 8 years ago
Hi, I am currently doing a project related to mixed IC design, for the digital part is the Digital PWM Generator Module design using verilog coding, and for the analogue part is the AC-DC & DC-DC boost converter design using Cadence Virtuoso.
For the digital PWM Generator module, I am using the the Synopsys DC + ICC to complete the RTL to GDSII flow,
and for the analogue AC-DC & DC-DC boost converter module it is full custom designed using Cadence Virtuoso.
I am having trouble passing the LVS in Cadence Virtuoso when I streamed in the GDSII file obtained from the ICC. Can someone kindly provide the step by step to stream in GDSII file from ICC into Cadence Virtuoso, passing the LVS & DRC and finally integrate the digital and analogue part in Cadence Virtuoso?
