  2. Mixed-Signal Design
  3. Unable to edit a cellview in a RAK
  • Replies 10
  • Subscribers 64
  • Views 21534
mhkvy4
mhkvy4 over 8 years ago
I was running the RAK for AMS designer and following the given instructions. When I try to open the example cellview in edit mode I get the following error:
Could not open "EXAMPLE top schematic " for edit.
dbOpenCellViewByType: Unable to lock database file for Example/top/schematic.
It seems I can only open it for read. This makes it impossible for me to complete the rest of the RAK because I cannot edit the file at all. Anyone know how I can open the example in edit mode and not read?
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago
    Try running the command below in the directory from where you are launching Virtuoso. It should release the locks in 'Example' library.
    clsAdminTool -are Example
    Saloni
  • mhkvy4
    mhkvy4 over 8 years ago in reply to Saloni Chhabra
    I ran the command above. It says that it released one edit lock but when I try to edit the config schematic or "Make it editable" it doesn't work. Should the command be run before or after launching virtuoso and attempting to open the cellview in edit mode?
  • Saloni Chhabra
    Can you also please confirm exactly which RAK are you working with? We'll fix the database so there are no edit locks in the first place.
    Saloni
  • mhkvy4
    intro to ams designer simulation version 9
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to mhkvy4
    I've just downloaded the RAK and there are no edit locks in the library, so they have most probably been created by you then. Do you have more than Virtuoso sessions open working on the same RAK?
    When a lock file does exist for a view, the Library Manger shows who has edit permissions for that view. Next to the view name, there is a column called 'Lock' showing this (empty Lock field will mean the file isn't open for editing by anyone). Can you check if your config view is locked?
  • mhkvy4
    it was an issue with some permissions which I managed to fix. However I am running into a new one when following the RAK and running the AMS simulation.
    I am getting the error that no connection module was found but I did include the connectlib libraries. I also tried compiling the amsConnectLibCompile script found in $AMSHOME/tools/affirma_ams/etc/install/amsConnectLibCompile
    The compile log gives me the error that ERROR:ncvlog binary does not exist or has wrong permissions
    I am also getting the following error when I am trying to create the netlist
    *ERROR*: Error encountered while registering text designs in the configuration.
    Refer to the following messages and correct the errors.
    ncvhdl: *E,BADTMPENV: ycalc: Failed to open Directory file..
    ncvhdl_p: *F,NOYOPN: cannot open file file '/tmpdir/ncvhdXXXXXX'.
    irun: *E,VHLERR: Error during parsing VHDL file (status 2), exiting.
    Andrew Beckett over 8 years ago in reply to mhkvy4
    First of all, it sounds as if the "configuration" step was not done when  installing your INCISIVE (or XCELIUM) installation. You should do that to ensure all reference libraries are compiled (InstallScape has a button to do configuration). Running the script would work if you have permissions, but you should ensure that <INCISIVEinstDir>/tools/bin is in your UNIX path before doing so.
    For the second error, do you have the $TMPDIR UNIX environment variable set? I get that error if I have $TMPDIR set to "/tmpdir" - not sure why you would do that if /tmpdir doesn't exist though.
  • mhkvy4
    mhkvy4 over 8 years ago in reply to Andrew Beckett
    The $TMPDIR env variable is not set to anything. Should it be set to something to avoid the error?
    Again the error is the same as before
    TOOL: irun(64) 15.20-s060: Exiting on Sep 23, 2018 at 01:31:29 CDT (total: 00:00:03)
    I can't see any way for this to happen without $TMPDIR being set somewhere. /tmpdir is not a normal default setting for the temporary dir location so I wouldn't expect it to be set somewhere.
    If you can't get to the bottom of this, please contact customer support.
  • mhkvy4
    Ok I just checked the env variable is set to /tmpdir
    What should the $TMPDIR env variable be set to? Or should I not use the variable at all?
    edit: The $TMPDIR env variable was set to /tmp and that fixed the issue. This thread can be closed now. Thanks for the help.
