  2. Mixed-Signal Design
  3. VerilogA Out-of-Module access top level nets?
  • Subscribers 63
  • Views 14919
billnxp
billnxp over 6 years ago
I want to probe some top level signals in my testbench.
I have a veriloga signal generator which creates a time varying waveform and I only want to capture signals during specific periods of this pattern,  so I need to capture the signals within this block.
I know I can add input pins and then deal with the signals that way,  but just out of interest (laziness?) I wanted to capture these signals directly from within the verilogA module.
All the examples show an out-of-module reference to another (sibling) instance, eg,
module x_siggen(....)
localparam string probethis="I1.signal";
analog begin
trackthis = V(probethis);
end
endmodule
etc.
How do I access a signal at the top level ?
If I simply use probethis = "topsignal" the editor parser fails with...
ERR516 [149:10]: 'probethis' is not an analog node or branch.
Is there some syntax to access the top level as well ?
