  2. Mixed-Signal Design
  3. SpiceIn netlist->schematic
  • Subscribers 64
  • Views 1943
paulinho
paulinho over 7 years ago
Hi ,
I'm using SpiceIn to import spice netlist into schematic view. I'm mapping the resistors to ideal models in analogLib. So I'm mapping resistor->res in the spiceIn settings (not using a device mapping file) so that it identifies analogLib.res...But in the log file its attempting to find analogLib.resistor, irrespective of the device mapping and throws out an error. Any idea on why this happens ?
    You have to use a device map to do the mapping. If you set the mapping up through the UI, you must save it (as far as I know) and then tell it to use the device mapping file on the first tab. I'm guessing you didn't do that, and so you've just got the default behaviour (i.e. no mapping).
    Perhaps you could clarify precisely how you set up the interface (maybe with some screenshots)?
