  2. Mixed-Signal Design
  3. Error with AMS simulator "Connect rules are not found in...
  • Subscribers 68
  • Views 16207
Error with AMS simulator "Connect rules are not found in your AMS installation"
alchemist87
alchemist87 over 7 years ago
Hi all,
this is my first attempt to perform an AMS simulation. I also checked the documentation and the forum without a working solution.
After the creation of the config view for the cell, I'm trying to load the connect rules from ADE L-> Setup -> Connect Rules/IR Setup but an error message appears saying "Connect rules are not found in your AMS installation".  It seems that, for whatever reason, the connectLib library with the built in connect rules is missing. I'm using IC6.1.7-64b.500.4 .
Thank you for support.
Best regards.
    Andrew Beckett over 7 years ago in reply to alchemist87 +1
    Hi Tonio, It sounds as if the Configure step wasn't done during installation. I think you should be able to go to the INCISIVE installation (as the user who owns the installation as you'll need write…
    A few things to check:
    1. Before starting Virtuoso, do you have an INCISIVE or ideally XCELIUM (XCELIUM is the replacement for INCISIVE) release in your path? For example, what do you get if you type "ncroot" or "xmroot" in the terminal window?
    2. If you do, which version are you using? "irun -version" will tell you (in the terminal window)
    3. In the path returned by step 1 above, can you then do (the bit in italics is the part you'll need to change) and show what it reports?
      ls -l /export/home/apps/XCELIUM1809_latest/tools/affirma_ams/etc/connect_lib/connectLib/*.pak
    4. In your cds.lib do you have something like:
      SOFTINCLUDE $AMSHOME/tools/inca/files/cds.lib
    The $AMSHOME is an env var pointing to the path given by step 1 above. It could be a full path - doesn't have to be an env var.
    It might be that the "configure" step wasn't done for the INCISIVE/XCELIUM release during installation - this builds the connectLib and compiles all the connect modules. The above should give us a clue though.
  • alchemist87
    alchemist87 over 7 years ago in reply to Andrew Beckett
    Dear Andrew,
    really appreciate your reply. Below are the checks you suggested:
    1) INCISIVE seems to be on my path. "ncroot" gives:
    /home/micro/eda/Cadence/2016-2017/lnx86/INCISIVE_15.20.010
    2) "irun -version" output:
    TOOL: irun 15.20-s022
    3) directory "connectLib" is missing from "/home/micro/eda/Cadence/2016-2017/lnx86/INCISIVE_15.20.010/tools/affirma_ams/etc/connect_lib/".
    4) the $AMSHOME env var is not present on my system. The path at step #1 is pointed by the $CDS_INCV env var instead.
    Please, can you point me on the right track about the configuration step?
    Thank you for your help.
    Best regards,
    Tonio
    Hi Tonio,
    It sounds as if the Configure step wasn't done during installation. I think you should be able to go to the INCISIVE installation (as the user who owns the installation as you'll need write permission) and do:
    sh ./installData/INCISIVE152_lnx86/batch_configure.sh
    This should compile all the libraries and the connectLib and so on.
  • alchemist87
    Dear Andrew,
    many many thanks for your help! After the compilation step I'm able to see the built-in connect rules in ADE L and I can successfully run AMS simulations!
    Best regards,
    Tonio
  • Burkland
    Burkland over 7 years ago in reply to Andrew Beckett
    Hello Andrew,
    I am having the same problem with the error "Connect rules are not found in your AMS installation".
    I have attempted to diagnosis the problem using the advise you gave in this thread:
    1a. When I type ncroot in the terminal window, I get: /usr/local/cadence/incisive
    1b. When I type xmroot in the terminal window, I get: xmroot: command not found
    2. When I type irun -version, I get: TOOL: irun(64) 15.20-s033
    3. When I type: ls -l /usr/local/cadence/incisive/tools/affirma_ams/etc/connect_lib/connectlib/*.pak
    I get: No such file or directory
    However, if I cd /usr/local/cadence/incisive/tools/affirma_ams/etc/connect_lib
    Then ls shows a number of files with the suffix .vams, but no connnectlib subdirectory.
    4. While it was not there initially, I have now added this line to my cds.lib
    SOFTINCLUDE /usr/local/cadence/incisive/tools/inca/files/cds.lib
    Based on the above, I concluded that the Configure step wasn't done as you advised the original poster. However, batch_configure.sh does not exist in the location that you indicated in our installation.
    Any advise on how to proceed?
    William Burkland
