  2. Mixed-Signal Design
  3. Simulation of simple Verilog-AMS testbench failed
  • Subscribers 64
  • Views 15202
pyohayo
pyohayo over 6 years ago
I've just tried to simulate simple ADC example using the following command:
irun adc.vams testbench.vams
... and got the following message:
irun: 12.10-s019: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
*WARNING* voInit failed to find the passwd entry for (null), using '/tmp' for a home directory.
The most likely cause of this problem is the failure of NIS lookups.
Any ideas ?
Thanks.
  • pyohayo
    I've tried the same command on the computer of my colleague (who has newer version of OS) and the error message is quite different:
    [Amsspice] *Error*: : No such file or directory
    irun: *E,SPCERR: The program encountered one or more errors while processing the input SPICE file(s) in the AMSD flow. For details, see the following messages.
    Strange ... after all both files are Verilog-AMS, not spice.
    Andrew Beckett over 6 years ago in reply to pyohayo
    You are using an ancient version of the simulator, which is probably not a good idea anyway (not sure why this would be happening without more details). So I'd start by using something more recent - ideally XCELIUM1903 or if not INCISIVE152, and if it's still an issue, contact customer support so that we can take a look.
