  2. Mixed-Signal Design
  3. I want to import with verilog in virtuoso(icfb)
  • Subscribers 64
  • Views 4793
JOILEB
JOILEB over 6 years ago
I have a standard cell lib with layout view, sch view, symbol
and I want to import verilog file which is composed o gate standard cell
when I use virtuoso File -> import -> verilog menu
I fill with Target Library Name, Reference Libraries, Verilog Files To Import, and Verilog Cell Modules
after push Apply or OK button
CIW says VerilogIn import completed. Plese look at logfile ./verilogIn.log
the Log says @(#)$CDS: ihdl.exe versin 5.1.0 10/28/2008 10:23 (cicln03) $ today's DATE
When I look Library Manager -> target library there is nothing
so I want to know How can I import verilog file
    That sounds reasonable other than using a 11 year old version of the software. I can't see from what you've shown above why it should be failing. Is there a good reason why you're using such an ancient version?
    Without seeing the data you're trying to import I'm not sure anyone can help that much - perhaps you should contact customer support (although there is a bit of a limit to what we can do if you're using such an old, no-longer-supported version).
  • JOILEB
    JOILEB over 6 years ago in reply to Andrew Beckett
    There is a reason why I using such an ancient version. because foundary vendor offer that version recommanded.
    When I using IC 6.1.7 ignoring foundary vendor's recommandation, the log syas ERROR (VERILOGIN-540): visadev load failed
    Andrew Beckett over 6 years ago in reply to JOILEB
    I doubt the problem with IC617 has any thing to do with the foundry's recommendation. It's more likely to do with your environment setup.
    See: ERROR (VERILOGIN-540): visadev load failed
  • JOILEB
    Yes, that's right. I try to change tool's version to 6.1.5 and then try again. It works perfectly!!!!! but 6.1.7 version tool doesn't work again
    So I conclude there are differences something
    Did you look at the article I referenced which talked about ensuring that your PATH and LD_LIBRARY_PATH are setup correctly?
    Either way, the best approach for this is customer support as I mentioned earlier.
