  2. Mixed-Signal Design
  3. WaveScan postprocessing question
  • Subscribers 64
  • Views 15444
pyohayo
pyohayo over 7 years ago
I want to realize the folowing post-processing scenario:
  1. Clip a particular signal, according to the following condition:
    clip(v("/grp1_clk" ?result "tran-tran") 0 cross(v("/grp1_adc" ?result "tran-tran") 0.9 1 "falling" nil nil))
  2. Then in this clipped signal I want to calculate the number of transitions. The command below get table of transitions
    cross(wave_33() 0.9 1 "rising" t "time"), where wave_33 - the waveform from p.1
  3. How to get the length of this table that is the number of transitions. The only way I found is to export table in Excel (.csv) and calculate it in Excel.
Probably dos exist some more "smart" method ?
Other question: how to use the name of clipped-signal expression from p. 1 (i.e. clipped_clk in my case) in the exprssion of p. 2 (wave_33 comes from WaveScan).
    The wavescan calculator doesn't allow you to name expressions and then use them later on. The wave_33() comes from how you can select a waveform in the graph and use it in the calculator, but it is created on the fly. In ViVA you can send a waveform to the calculator with the expression used to create it, or you can give the expression a name and then use that - but in the ancient tool you're using, you can't.
    You could of course nest the expression:
    length(cross(clip(v("/grp1_clk" ?result "tran-tran") 0 cross(v("/grp1_adc" ?result "tran-tran") 0.9 1 "falling" nil nil)) 0.9 0 "rising"))
    The cross function, if given 0 as the crossing number (and omitting the t and "time" arguments) will return a list of the crossing points, and you can then use the SKILL length function to find how many there were.
  • pyohayo
    pyohayo over 7 years ago in reply to Andrew Beckett
    Works fine. Thanks Andrew.
