  2. Mixed-Signal Design
  3. Ocean Script (AMS simulator): How to save only an analog...
  • Subscribers 64
  • Views 16038
Ocean Script (AMS simulator): How to save only an analog net from an analog bus
hippoo
hippoo over 7 years ago
May I know how to modify the following ocean script to save only the an analog net from an analog bus, e.g. to save only ABC<0> from ABC<0:10>?
The following script is going to save all the ABC<0:10> instead of ABC<0> only:
ocnWaveformTool( 'wavescan )
simulator( 'ams )
solver( 'UltraSim )
saveOption( 'save "selected" )
save( 'v "/ABC<0>" )
Thanks in advance!
  • RiadKaced
    RiadKaced over 7 years ago +1
    Hi Hippoo, That's the right syntax, do you have any issues with it? If so then please post your Virtuoso and AMS versions
  • RiadKaced
    Hi Hippoo,
  • hippoo
    hippoo over 7 years ago in reply to RiadKaced
    Hi RiadKaced,
    Yup, you are right. I tried with the latest version. The issue resolved.
    Thank you very much!
