  2. Mixed-Signal Design
  3. Device model fitted on a set of value
  • Subscribers 64
  • Views 15074
INLheterogenous
INLheterogenous over 6 years ago
in order to interface TCAD tools with cadence, is it possible to give a sufficiently rich table of data (multidimensionnal for all parameters I wish to modify) to a specific tool of Cadence so it generates a Verilog(-A) model file, (for instance based on a set of general purpose fitting equations). That way I can use those TCAD results in spectre simulations thanks to a compact model in order to scale up.
I saw the function "table_model" but I don't think this is what I am looking for.
Thanks for your answer,
Anaud
    Anaud,
    Why do you think that table_model doesn't do what you want? That's precisely the kind of thing it's for...
  • INLheterogenous
    INLheterogenous over 6 years ago in reply to Andrew Beckett
    Thank you Andrew for your fast answer,
    I couldn't find any informations about it so I asked, now that you confirmed it is what I need, I found the documentation and I will try to use it.
    Arnaud
    • Add to Phrasebook
      • No word lists for English -> English...
      • Create a new word list...
    • Copy
