  2. Mixed-Signal Design
  3. Building Config tree for System Verilog Testbench when using...
  • Subscribers 64
  • Views 17746
Building Config tree for System Verilog Testbench when using external HDL
svuser
svuser over 6 years ago
I have a hierarchial external HDL testbench. I am wanting to use the config editor to have a full hierarchy tree of the System Verilog testbench. My issue is that unless I copy the HDL code into individual SV views inside a library in Virtuoso, the instantiated modules within the HDL cannot be found to build the tree view. Is there a way I can have the config tree populate the submodules without having to copy the code into each SV view per module?
Thanks!
    No. The hierarchy editor can only see modules that are within the Virtuoso libraries. You could use cdsTextTo5x to import it instead if that makes it easier?
