  2. Mixed-Signal Design
  3. bus instances of the AMS netlisting
  • Subscribers 64
  • Views 16243
GavinAMS
GavinAMS over 6 years ago
I am running a AMS simulations and when it netlisted all the bus instances, it only change the left side "<" to the "_". For example, I1<1:0>, in the netlist, the names are I1_1, I1_0, instead of I1_1_ and I1_0_. Although the simulation could run, the annotation of SDF files can't annotation them because of the name mismatches. Did anybody have this problem before and what is the solution for it.
Thanks.
    I'm not convinced this is a good idea, but you can put this in the .simrc file:
    hnlMapInstInName=
    '((">" "_") ("<" "_") ("." "_") ("#" "\\#") ("$" "\\$") ("%" "\\%") ("^" "\\^") ("&" "\\&") ("*" "\\*") ("(" "\\(") (")" "\\)") ("\\" "\\\\") ("|" "\\|") ("+" "\\+") ("-" "\\-") ("=" "\\=") ("{" "\\{") ("}" "\\}") ("[" "\\[") ("]" "\\]") ("\"" "\\\"") ("'" "\\'") (":" "\\:") (";" "\\;") ("~" "\\~") ("`" "\\`") ("," "\\,") ("?" "\\?") ("/" "\\/") ("@" "\\@"))
    This has all the normal mappings, but with the close angle mapped to underscore rather than "". This will then affect all netlisters - I'm not sure you can easily make it AMS UNL-specific.
    Probably best to follow up with customer support to find the right way forward.
  • GavinAMS
    GavinAMS over 6 years ago in reply to Andrew Beckett
    Thank you, Andrew. I will contact the customer support.
