  2. Mixed-Signal Design
  3. Accessing LINUX environment variables in verilog-AMS/verilog...
  • Subscribers 64
  • Views 6952
Accessing LINUX environment variables in verilog-AMS/verilog-A
LDIL
LDIL over 6 years ago
Hello all.
Does anyone know how to do that?
One can do that in systemVerilog, but I could not find the same for verilog-a or verilog-AMS.
Thanks!
    Andrew Beckett over 6 years ago +1
    What are you hoping to do with these environment variables? Maybe you don't need to evaluate them - for example, the $fopen() function will accept paths containing environment variables and read/write…
    What are you hoping to do with these environment variables? Maybe you don't need to evaluate them - for example, the $fopen() function will accept paths containing environment variables and read/write files with the evaluated values of those env vars.
    How are you doing it in SystemVerilog?
  • LDIL
    LDIL over 6 years ago in reply to Andrew Beckett
    Hi Andrew.
    In short, import "DPI-C" function string getenv(input string env_name);
    Here it is in SystemVeilog, the full thread.
    https://stackoverflow.com/questions/15034019/how-do-i-read-an-environment-variable-in-verilog-system-verilog#15103561
    I was trying to get certain printouts done when an environment variable was set.
    Thanks.
    Andrew Beckett over 6 years ago in reply to LDIL
    I don't think this is possible with Verilog-A (I didn't check with Verilog-AMS). You might have been able to do:
    import "CDS_VA_DPI" function string getenv(string varname);
    except that this approach doesn't support string return values or string arguments.
    I think you would need to contact customer support for an enhancement.
  • LDIL
    Thanks Andrew.
    Happy new year!
