  2. Mixed-Signal Design
  3. timer equivalent for "DC " analysis for verilog-a
  • Subscribers 64
  • Views 2804
LDIL
LDIL over 6 years ago
Hi. If there is an "ac" or "dc" analysis, how can one add an event (such as @(cross( ) ), or @timer in transient. How can one do @( function ), which would stop when dc is, for example, 20, , say ac in 5GHz. Thanks.
    The @(cross...) is purely for time-domain events, but you can use @(above(...)) - for example:
    @(above(V(p,n))) begin
      $strobe("ABOVE = ",V(p,n));
    end
    above(x <, timetol <, abstol <, enable >>>)
    Generates an event when 'x' becomes greater than or equal to zero. An above event can be generated and detected during initialization. By contrast, a cross event can be generated and detected only after at least one transient time step is complete.
    So it's not quite what you're asking, but may be sufficient for the DC case at least. In a dc sweep the above will trigger as the x expression becomes positive. In general Verilog-A models should be written to operate in the time-domain and you should not try to write different behaviour for different analyses. In an ac analysis, the equations described in the VerilogA model are linearised and then simulated in the small-signal AC analysis. It does not then execute the code during the AC as it's simulating the small-signal linear model instead, and so you cannot have something that is triggered at a particular frequency - it makes no sense in VerilogA.
