  2. Mixed-Signal Design
  3. multiple macro definitions in verilog-a
  • Subscribers 64
  • Views 15997
LDIL
LDIL over 6 years ago
Hi.
Let's say I am running a verilog-a block, and I want to use two macros, what is the syntax, for the command line arguments?
ie. -va, define FOO=1 and I want also BAR=2
How is that done?
Thanks.
-Lior
    Andrew Beckett over 6 years ago +1
    You simply do: -va,define FOO=1 -va,define BAR=2 Regards, Andrew.
    You simply do:
