  2. Mixed-Signal Design
  3. How to use +sv option in AMS simulation
  • Subscribers 64
  • Views 20562
happyy
happyy over 6 years ago
Hi there:
I run into some AMS simulation problem with systemVerilog, please help.
AMS worked fine for mixed signal simulations with default settings till I have to use a new digital block with array definition, like this
input [31:0] dc_offset [0:15];
It simply could not pass compile and generate netlist. To solve this problem, I added '+sv' option in  simulation -> option -> AMS simulator -> Main -> Additional argument. Then a netlist was successfully created. But when I tried to run it, all kinds of syntax errors are reported, caused by connect rules, which I used successfully before I add +sv option. It seems systemVerilog language is not compatible with the syntax which we normally used in connect rules. A few examples are shown blow:
xmvlog: *E,NOIPRT (/ecad/cadence/xcelium1710.004/tools.lnx86/spectre/etc/ahdl/disciplines.vams,46|9): Unrecognized declaration 'discipline' could be an unsupported keyword, a spelling mistake or missing instance port list '()' [SystemVerilog].
xmvlog: *E,NCUITEM (/ecad/cadence/xcelium1710.004/tools.lnx86/spectre/etc/ahdl/disciplines.vams,46|9): Not a valid compilation unit/global item: 'interface_declaration' [SystemVerilog].
Does anyone have a solution for using 2-dimension array in AMS mixed signal simulation?
    Andrew Beckett over 6 years ago +1
    Well, you shouldn't add +sv because that forces systemVerilog compilation for everything which will break all Verilog-AMS files (as they are not SystemVerilog). There's no reason why you can't have this…
    There's no reason why you can't have this digital block either as an external file with a ".sv" suffix, or as a SystemVerilog view type in Virtuoso. Then that block will be compiled as SystemVerilog and other blocks will be compiled using whatever language they are written in.
  • happyy
    happyy over 6 years ago in reply to Andrew Beckett
    Yes, you are right. Changing file type went through netlisting. Thank you!
