  2. Mixed-Signal Design
  3. IP3 Simulation of a Sample and Hold Circuit in Spectre
  • Subscribers 64
  • Views 20718
growingmind
growingmind over 6 years ago
I want to measure the IP3 of a Sample and Hold (clocked) using Cadence Spectre.
What is the best procedure for this ? QPSS or PSS ?
I want to sweep over input voltage.
The circuit diagram is attached.  Just a simple tgate switch with a hold cap clocked at 2GHz, followed by a buffer then another tgate switch and a hold cap.
Input is a 50Mhz sine wave at 5mV.
Thank you.
    I was about to answer this, but I see Ken answered the identical question you asked on the Designer's Guide Forum.
