  2. Mixed-Signal Design
  3. ncelab: *N,DLWTLK
  • Subscribers 64
  • Views 2485
ncelab: *N,DLWTLK
ykhuang
ykhuang over 6 years ago
I have trouble running the ams simulation. When I tried to run the simulation, the error message popped up:
ncelab: *N,DLWTLK: Pausing until a shared lock can be established on library 'std'.  Another process may be accessing the library.  Process will resume when the lock is established.
What does this error message mean and does anyone know how to solve this problem?  Thank you in advance!
  • Saloni Chhabra
    Saloni Chhabra over 6 years ago
    You can find information on this error message here:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nTG5EAM&pageName=ArticleContent
    Can you check if you've run out of disk space?
    Saloni
