  2. Mixed-Signal Design
  3. AMS simulations, files and variables not found
  • Subscribers 64
  • Views 15731
tahirsengine
tahirsengine over 6 years ago
I am working in a large team. I am at Digital side, and working with ModelSim. I have made many test cases for different system aspects.
The guy working on Analog side is working with Cadence Virtuoso.
The files: Testcase + include files + testbench + system design files, I have already handed over to him.
The problem, however is as follows: Every time he runs the simulation, software at his end complains about the files and variables missing, which are already there and working in Mentor tools.
I told him about the sequence of execution, but he says this point is not valid for Cadence. So can anyone please inform how Cadence tools refer to variables and tasks present in other files? I mean is there any particular way that we pass files to Cadence system? Any clue? Or the file connected with each other, and that set of files working in Mentor, will also work in Cadence?
  • tahirsengine
    tahirsengine over 6 years ago +1
    Please note that all system files are in Verilog and tests and test files are all in Systemverilog
    Andrew Beckett over 6 years ago in reply to tahirsengine +1
    Please contact customer support . I don't see any generic reason why there should be a problem, so there may just be some subtle issue with the setup which is wrong. That's best handled via support as…
  • tahirsengine
    Please contact customer support. I don't see any generic reason why there should be a problem, so there may just be some subtle issue with the setup which is wrong. That's best handled via support as we'd really want to be able to see the data and setup.
