  2. Mixed-Signal Design
  3. Amplitude sweep in VERILOG-A environment to generate multiple...
  • Subscribers 64
  • Views 15250
Amplitude sweep in VERILOG-A environment to generate multiple Output files through the Verilog-A code
Jaikrishnan
Jaikrishnan over 6 years ago
I am doing a simulation in Cadence for a Delta-Sigma ADC with blocks like op-amp and Quantizer modeled in Verilog-A environment. The quantizer is a single-bit quantizer and hence modelled just as a comparator that works on a clock with V(out) = +1 when the V(in) > 0 and V(out) = -1 when the V(in) < 0. In the quantizer block, I have a code piece that does a file export in .dat format (@filecheck (path of the destination to store the file)). This is performed because I will load this file generated into Matlab and verify the performance metrics like SNR and IBN through the code run in Matlab.
Now I want to sweep that amplitude lets say for 100 levels between a minimum and maximum. With this, I would like to generate 100 file outputs on each iteration such that I can load that in Matlab using an iteration of 100 levels.
How can I modify the Verilog-A code so as to generate each file at each amplitude iteration without just replacing the existing file each time?
Below is the current code:
module Quantizer(in,clk,out),
input in,clk,
output clk,
voltage in,clk,out;
parameter real tr = 1n, tf= 1n, tdel = 1n;
integer file_check = 0;
real vin, out_var;
analog
begin
if(analysis("tran"))
begin
file_check = $fopen("path to store the file")
@cross(V(clk)-0.5,+1)
begin
vin = V(in);
if(vin>0)
out_var = 1;
else begin
out_var = -1;
end
$fstrobe(file_check,"%g",out_var)
end
end
@(finalstep) begin
$fclose(file_check);
end
V(out)<+transition(out_var,tdel,tr,tf)
end
endmodule
Can some one help me to midy the same code according to my need?
