  2. Mixed-Signal Design
  3. Loading SHM file in VIVA
  • Subscribers 64
  • Views 16895
debaabed
debaabed over 6 years ago
Hi All
I am running a AMS simulation and want to post-process some of the analog waveforms in VIVA. The waveform dump created by simulation is in *.shm format and contains multiple *.trn files.
Is it possible to load the *.shm file in VIVA? For some reason, due to multiple *.trn files, its not able to give the full waveform. It only gives a part of it.
DB
    I'm not sure why there would be multiple separate files in the result database. Probably best to contact customer support so we can look at your set up and understand why this is happening?
  • caitlincady
    caitlincady over 6 years ago in reply to Andrew Beckett
    Will do. Thank you!!
    png to ico
