  2. Mixed-Signal Design
  3. Schematic instance showing the config view selected.
  • Subscribers 64
  • Views 15705
Selcuk T
Selcuk T over 5 years ago
Is it possible to show the view selected in hierarchy editor for an instance in schematic in virtuoso?
I have 2 views for an instance; schematic and functional. I want to see in schematic which view is used for that instance in the opened config view.
Selcuk
    Andrew Beckett over 5 years ago in reply to Selcuk T +1
    Well maybe this article (one of mine) might help SKILL : Adding a label to a symbol to indicate which view is used from a config - although I suspect you're wanting a visual annotation which doesn't need…
    Selcuk,
    In the configured schematic, do Launch->Plugins->Hierarchy Editor, and then pick Hierarchy Editor->Show Views Found
  • Selcuk T
    Selcuk T over 5 years ago in reply to Andrew Beckett
    Thanks Andrew,
    What I was looking for is more like annotating the view (the one selected HED for this instance) on the instance in virtuoso.
    Similar to showing the instance name I want to see the view selected. Is it possible?
    Well maybe this article (one of mine) might help SKILL : Adding a label to a symbol to indicate which view is used from a config - although I suspect you're wanting a visual annotation which doesn't need adding a label onto the symbol.
    You could use the code in that article together with this code here; you simply select the instances you want to annotate (or cross-select from the hierarchy editor) and call CCFannotateView() (maybe from a bindkey). You can also use CCFclearAnnotateView() to clear all the annotations.
    procedure(CCFannotateView(@key (instances geGetSelSet())
            (window hiGetCurrentWindow()) (lpp list("y0" "drawing"))
            (height 0.0625)
        let((hs bBox)
            hs=window~>CCFannotateViewHS ||
                geCreateHilightSet(geGetEditCellView(window) lpp)
            foreach(inst instances
                when(inst~>objType=="inst"
                    bBox=dbTransformBBox(
                        dbComputeBBoxNoNLP(inst~>master)
                        inst~>transform
                    when(bBox
                        geAddHilightLabel(hs centerBox(bBox) CCSwhichView(inst)
                            "centerCenter" "R0" "stick" height t)
            hs~>enable=t
            window~>CCFannotateViewHS=hs
            t
    procedure(CCFclearAnnotateView(@key (window hiGetCurrentWindow()))
        let((hs)
            when(hs
                geDeleteHilightSet(hs)
                window~>CCFannotateViewHS=nil
                t
  • Selcuk T
    Thanks Andrew! This is exactly what I was looking for!
