  2. Mixed-Signal Design
  3. AMS simulation fails when I use mim cap
  • Replies 15
  • Subscribers 64
  • Views 23698
Mostafa A
Mostafa A over 5 years ago
Hi everybody,
I am doing AMS simulation using the version 6.1.5. I am using 65nm TSMC. When I run simulation it fails because of the mim caps that I used in analog parts. And when I replace the mim caps with the ideal caps it works.
Does anyone know what could be the problem?
Best
Mostafa
    Andrew Beckett over 5 years ago in reply to Mostafa A
    Within the netlist directory /ECEnet/Apps1/ecl/users/Mostafa/TSMC_65nm_DESIGN/sim/Boost_HillClimbing2/ams/config/netlist there will be  amsControlSpectre.ahdlSimDB/bsource_1.amsControlSpectre.ahdlcmi/Linux3.10.0-1062.9.1.el7.x86_64+gcc/../ahdlcmi.out - so that would be (I think):
     /ECEnet/Apps1/ecl/users/Mostafa/TSMC_65nm_DESIGN/sim/Boost_HillClimbing2/ams/config/netlist/amsControlSpectre.ahdlSimDB/bsource_1.amsControlSpectre.ahdlcmi/Linux3.10.0-1062.9.1.el7.x86_64+gcc/../ahdlcmi.out
    I still think this is just making life hard for. yourself though - why use such an ancient version?
  • Mostafa A
    Mostafa A over 5 years ago in reply to Andrew Beckett
    Yes you are right. I will reach out to cadence contact point in our school for newer INCISIV version. It might take time. That is why I want to make it also work.
    What I see in the path is:
    there is no "ahdlcmi.out" !!
    "ahdlcmidevicelist" is not readable.
    And what I see in "ahdlcmidevicelist" is:
    Best
    Mostafa
  • Mostafa A
    Mostafa A over 5 years ago in reply to Mostafa A
    I see something here (not exactly in the path mentioned in the log file):
    And its content is:
    ahdlcmicompile: Compiling ahdlcmi in amsControlSpectre.ahdlSimDB/bsource_1.amsControlSpectre.ahdlcmi/Linux3.10.0-1062.9.1.el7.x86_64+gcc/ for Linux3.10.0-1062.9.1.el7.x86_64+gcc with optimize using gcc on Wed Nov 11 13:45:05 EST 2020 [5.0]
    ahdlcmicompile: Generating makefile
    PATH: /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.1/install/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/bin/64bit:/ECEnet/Apps1/linux/cad12/tools//cadence/IC615/oa_v22.41.017/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/fet/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/pcb/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/mainwin530/mw/bin-i86_linux:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/mainwin530/mw/bin-linux_optimized:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/mainwin530/mw/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/jre/bin:/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/astro_vZ-2007.03-SP12/bin/IA.32:/ECEnet/Apps1/linux/cad12/tools//synopsys/astro_iu_vZ-2007.03-SP12/bin/IA.32:/ECEnet/Apps1/linux/cad12/tools//synopsys/astro-rail_vZ-2007.03-SP11/bin/IA.32:/ECEnet/Apps1/linux/cad12/tools//synopsys/cosmosscope_vE-2011.03/ai_bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/customdesigner_vE-2011.03/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/customexp_vE-2010.12/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/hercules_vB-2008.09-SP4/bin/IA.32:/ECEnet/Apps1/linux/cad12/tools//synopsys/hsimplus_vF-2011.09/hsimplus/platform/linux/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/hspice_vF-2011.09-SP2/hspice/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/hspice_vF-2011.09-SP2/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/IC_COMPILER_vF-2011.09-SP4/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/pts_vF-2011.12-SP2/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/scl_v11.3/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/starrc_vF-2011.12-SP2/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/SYNTHESIS_vF-2011.09-SP4/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/tcad_sentaurus_vF-2011.09-SP1/bin:/ECEnet/Apps1/linux/cad12/tools//synopsys/vcs_mx_vF-2011.12/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/ASSURA41/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/ASSURA41/tools/dfII/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/EXT101/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/EXT101/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/MMSIM101/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/IC615/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/IC615/tools/dfII/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/IC615/tools/spectre/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/CTOS102/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/CONFRML101/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/SPB165/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/SPB165/tools/lib:/ECEnet/Apps1/linux/cad12/tools//cadence/SPB165/tools/pcb_bin:/ECEnet/Apps1/linux/cad12/tools//cadence/SPB165/tools/fet/bin:/ECEnet/Apps1/linux/cad12/tools//tools/bin:/ECEnet/Apps1/linux/cad12/tools//tools/lib:/ECEnet/Apps1/linux/cad12/tools//bin:/ECEnet/Apps1/linux/cad12/tools//lib:/ECEnet/Apps1/linux/cad12/tools//cadence/ADW165/tools/bin:/ECEnet/Apps1/linux/cad12/tools//bin:/ECEnet/Apps1/linux/cad12/tools//cadence/INCISIV102/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/INCISIV102/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/INCISIV102/tools/systemc/gcc/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/INCISIV102/specman/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/INCISIV102/tools/vtools/vfault/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/ETS101/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/ET101/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/RC101/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/EDI101/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/pas31/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/INCISIV102/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/INCISIV102/tools/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/PACIFIC61/bin:/ECEnet/Apps1/linux/cad12/tools//cadence/PACIFIC61/share/pacific/scripts:/ECEnet/Apps1/linux/cad12/tools//mentor/calibre_2010.3_37.26/ixl_cal_2010.3_37.26/bin:/ECEnet/Apps1/linux/cad12/tools//mentor/modelsim_se_10.1a/modeltech/bin:/Users/Grad/abedimo64:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/etc:/usr
    LD_LIBRARY_PATH: /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.1/install/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools/lib/64bit:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/oa_v22.41.017/lib/linux_rhel40_gcc44x_64/opt:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/Qt/64bit/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/dfII/lib/64bit:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/sev/lib/64bit:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/lib/64bit:/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/lib/64bit:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/jre/lib/i386/server:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/jre/lib/i386:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/mainwin530/mw/../misc/linux/gcc/fixed3/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/fet/bin:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/mainwin530/mw/lib-linux_optimized:/usr/dt/lib:/usr/openwin/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/dfII/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/jre/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/jre/lib/i386/client:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/jre/lib/i386/native_threads:/ECEnet/Apps1/linux/cad12/tools/cadence/SPB165/tools/jre/lib/i386:/ECEnet/Apps1/linux/cad12/tools//cadence/MMSIM101/tools/ultrasim/lib:/ECEnet/Apps1/linux/cad12/tools//cadence/IC615/tools/dfII/lib:/ECEnet/Apps1/linux/cad12/tools//cadence/IC615/oa_v22.41.017/lib:/COEnet/Linux/lib/X11R6/lib:/usr/X11R6/lib:/ECEnet/Apps1/linux/cad12/tools//ciranova/cni_47/plat_linux_gcc44x_32/3rd/lib:/ECEnet/Apps1/linux/cad12/tools//ciranova/cni_47/plat_linux_gcc44x_32/3rd/oa/lib/linux_rhel40_gcc44x_32/opt:/ECEnet/Apps1/linux/cad12/tools//ciranova/cni_47/plat_linux_gcc44x_32/lib:/ECEnet/Apps1/linux/cad12/tools/cadence/IC615/tools/dfII/lib
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j5 -f GNUmakefile
    Compiling C file bsource_1_func.c (optimize) with -O0
    Compiling C file bsource_1_DcFuncDerLoad.c (optimize)
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O0 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -c bsource_1_func.c -o obj/optimize/5.0/bsource_1_func.o || rm -f -f obj/optimize/5.0/bsource_1_func.o
    Compiling C file bsource_1_DcFuncLoad.c (optimize)
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -c bsource_1_DcFuncDerLoad.c -o obj/optimize/5.0/bsource_1_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/bsource_1_DcFuncDerLoad.o
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -c bsource_1_DcFuncLoad.c -o obj/optimize/5.0/bsource_1_DcFuncLoad.o || rm -f -f obj/optimize/5.0/bsource_1_DcFuncLoad.o
    Compiling C file bsource_1_TranFuncDerLoad.c (optimize)
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -c bsource_1_TranFuncDerLoad.c -o obj/optimize/5.0/bsource_1_TranFuncDerLoad.o || rm -f -f obj/optimize/5.0/bsource_1_TranFuncDerLoad.o
    Compiling C file bsource_1_TranFuncLoad.c (optimize)
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -c bsource_1_TranFuncLoad.c -o obj/optimize/5.0/bsource_1_TranFuncLoad.o || rm -f -f obj/optimize/5.0/bsource_1_TranFuncLoad.o
    In file included from /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/install/lib/gcc/i686-pc-linux-gnu/4.4.0/include-fixed/features.h:351,
    from /usr/include/math.h:27,
    from bsource_1_DcFuncLoad.c:1:
    /usr/include/gnu/stubs.h:7:27: error: gnu/stubs-32.h: No such file or directory
    from bsource_1_func.c:1:
    from bsource_1_TranFuncDerLoad.c:1:
    from bsource_1_DcFuncDerLoad.c:1:
    from bsource_1_TranFuncLoad.c:1:
    rm -f -rf bsource_1_DcFuncDerLoad.c
    rm -f -rf bsource_1_func.c
    rm -f -rf bsource_1_DcFuncLoad.c
    Compiling C file bsource_1_OpPointCalc.c (optimize)
    rm -f -rf bsource_1_TranFuncLoad.c
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -c bsource_1_OpPointCalc.c -o obj/optimize/5.0/bsource_1_OpPointCalc.o || rm -f -f obj/optimize/5.0/bsource_1_OpPointCalc.o
    Compiling C file bsource_1_CreateDevice.c (optimize)
    rm -f -rf bsource_1_TranFuncDerLoad.c
    Compiling C file bsource_1_cmi_c.c (optimize)
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/cmi/include -c bsource_1_cmi_c.c -o obj/optimize/5.0/bsource_1_cmi_c.o || rm -f -f obj/optimize/5.0/bsource_1_cmi_c.o
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -march=i686 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include -c bsource_1_CreateDevice.c -o obj/optimize/5.0/bsource_1_CreateDevice.o || rm -f -f obj/optimize/5.0/bsource_1_CreateDevice.o
    from bsource_1_OpPointCalc.c:1:
    from /usr/include/setjmp.h:25,
    from /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:22,
    from bsource_1_cmi_c.c:2:
    from bsource_1_CreateDevice.c:1:
    bsource_1_cmi_c.c: In function 'bsource_1_pSaveRestart':
    bsource_1_cmi_c.c:821: warning: passing argument 2 of 'aslAvarSR' from incompatible pointer type
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:811: note: expected 'struct ahdlAnalogVar *' but argument is of type 'char *'
    rm -f -rf bsource_1_cmi_c.c
    rm -f -rf bsource_1_OpPointCalc.c
    rm -f -rf bsource_1_CreateDevice.c
    /ECEnet/Apps1/linux/cad12/tools/cadence/INCISIV102/tools.lnx86/systemc/gcc/4.4/bin/gcc -shared -O3 -fPIC -o obj/optimize/5.0/libahdlcmi.so ./obj/optimize/5.0/bsource_1_func.o ./obj/optimize/5.0/bsource_1_DcFuncDerLoad.o ./obj/optimize/5.0/bsource_1_DcFuncLoad.o ./obj/optimize/5.0/bsource_1_TranFuncDerLoad.o ./obj/optimize/5.0/bsource_1_TranFuncLoad.o ./obj/optimize/5.0/bsource_1_OpPointCalc.o ./obj/optimize/5.0/bsource_1_CreateDevice.o ./obj/optimize/5.0/bsource_1_cmi_c.o -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
    gcc: ./obj/optimize/5.0/bsource_1_func.o: No such file or directory
    gcc: ./obj/optimize/5.0/bsource_1_DcFuncDerLoad.o: No such file or directory
    gcc: ./obj/optimize/5.0/bsource_1_DcFuncLoad.o: No such file or directory
    gcc: ./obj/optimize/5.0/bsource_1_TranFuncDerLoad.o: No such file or directory
    gcc: ./obj/optimize/5.0/bsource_1_TranFuncLoad.o: No such file or directory
    gcc: ./obj/optimize/5.0/bsource_1_OpPointCalc.o: No such file or directory
    gcc: ./obj/optimize/5.0/bsource_1_CreateDevice.o: No such file or directory
    gcc: ./obj/optimize/5.0/bsource_1_cmi_c.o: No such file or directory
    gnumake: *** [obj/optimize/5.0/libahdlcmi.so] Error 1
    Is it the file you were referring to?
    It appears from the messages that your machine may be missing the glibc-devel package (RPM) which provides the file /usr/include/gnu/stubs-32.h
    So you'll probably need your school's IT to install this operating system package on the machine (at least I think that's what the error is pointing to).
  • Mostafa A
    Thanks dear Andrew.
