  2. Mixed-Signal Design
  3. ncsim: *F,RNAERR: The simulator terminated with an analog...
  • Subscribers 64
  • Views 8493
ncsim: *F,RNAERR: The simulator terminated with an analog initialization error.
RFStuff
RFStuff over 5 years ago
Dear All,
I installed INCISIV152 and I tried to run a AMS simulation using ADE-L. It ran successfully.
When I used ADE-XL for the same set-up, I got the following errors.
ncelab: Memory Usage - 49.9M program + 59.2M data = 109.1M total (Peak 243.3M)
ncelab: CPU Usage - 0.1s system + 0.2s user = 0.3s total (0.3s, 94.2% cpu)
Loading snapshot param7_ams.tb_ssc:config .................... Done
ncsim: *W,NXDMSO: This design will require a check out of DMSO license when it is run with Xcelium.
Simulating in AMS-SIE mode...
ncsim: *W,DSEM2009: This SystemVerilog design is simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics.
Starting analog simulation engine...
AMSD encountered an error: Invalid command-line arguments for spectre solver: +logstatus
See the Virtuoso AMS Designer Simulator User Guide for valid arguments of spectre solver.
ncsim: Memory Usage - 38.6M program + 286.6M data = 325.3M total (326.1M Peak)
ncsim: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.1s, 82.5% cpu)
TOOL: irun(64) 15.20-s086: Exiting on Jan 04, 2021 at 19:08:10 IST (total: 00:00:11)
    I answered this recently in this post.
  • RFStuff
    RFStuff over 5 years ago in reply to Andrew Beckett
    Thanks Andrew. The simulation ran.
    But, when I am trying to change the Analysis (like the simulation time of Tran), it is not taking. I get the following error in CIW.
    *Error* geGetTopLevelCellView: argument #1 should be a window type (type template = "w") - nil
    Andrew Beckett over 5 years ago in reply to RFStuff
    Can you please let me know what getVersion(t) returns? Then do the following:
    _stacktrace=50
    and repeat changing the analysis - then report what it shows in the CIW. If it still only shows just one line, try also:
    sstatus(errsetTrace t)
    and try again.
    This may help me narrow down what's failing (I did a quick search and didn't find anything obvious).
  • RFStuff
    Dear Andrew,
    I closed CIW and restarted virtuoso.
    I entered
    _amsUISimFeatures->spectre_commandline_logstatus=nil     in CIW.
    I then did-->
    getVersion(t)
    "sub-version IC6.1.8-64b.500.14 "
    _stacktrace=50
    50
    I then changed the analysis. I didn't see anything in CIW and I see the change is being taken.
    I entered  the command sstatus(errsetTrace t) and then I changed the analysis and ran the sim. The simulation ran successfully though with following errors at the beginning.
    simulation run.
    *Error* lineread/read: syntax error encountered in input at line 1 column 121 in file *ciwInPort*
    <<< Stack Trace >>>
    (... in _axlRunAllTestsWithCallback ...)
    (... in axlRunSimulation ...)
    axlRunSimulation()
    *Error* lineread/read: syntax error encountered in input at line 1 column 97 in file *ciwInPort*
    <<< Stack Trace >>>
    (... in unknown ...)
    funobj@0x4b4b4598()
    (... in _axlQuietLineReadString ...)
    (... in _axlEvaluateOpAcrossExpressionHelper ...)
    (... in _axlExprContainsSpecialKeywordWithHistory ...)
    (... in _axlExprContainsCalcValWithHistory ...)
    (... in _axlGetCalcValFromExpression ...)
    _axlGetCalcValFromExpression("\"File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/fet.lib.scs Section=\"TT\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/res.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/cap.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/bipolar.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/diode.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/ind.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/prelayout.lib.scs Section=\"ON\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/montecarlo.lib.scs Section=\"ALL_ON\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/includes.scs Section=\"15M\";\"" ?isRunPlanRun nil)
    (... in _axlOrderVariables ...)
    (... in _axlICRPApplyVariables ...)
    (... in _axlPrepare ...)
    funobj@0x46d6a2c8()
    funobj@0x46d6a138()
    (... in _axlRunPoint ...)
    (... in _axlRunAll ...)
    (... in _axlToolRunAllMethod (axlToolAdeAbstract t t) ...)
    (... in _axlToolRunAllCore ...)
    funobj@0x46d69c00()
    (... in _axlEnsureCleanUpFunction ...)
    (... in _axlFuncForExecuteInTheContextOf ...)
    (... in _axlCallInICXPClientContextMethod (axlICLPClient t) ...)
    (... in _axlCallInICXPClientContext ...)
    (... in _axlToolRunAll ...)
    _axlToolRunAll(7 (("toolname" "ADE") ("testname" "param7_ams:tb_ssc:1") ("pointid" (&)) ("simreqid" 4) ("resdbpath" "/A/manas/manas/work_cad_IC616_130nm/SERDES_PCIE/param7_ams/tb_ssc/adexl/results/data/Interactive.93.rdb") ... ))
    funobj@0x46d69b60()
    _axlFuncForExecuteInTheContextOf()
    <<< Stack Trace >>>
    funobj@0x4b4b4598()
    funobj@0x46d6a2c8()
    funobj@0x46d6a138()
    funobj@0x46d69c00()
    funobj@0x46d69b60()
    <<< Stack Trace >>>
    funobj@0x4b4b4598()
    (... in _axlGetVARDependenciesInExpressions ...)
    _axlGetVARDependenciesInExpressions("\"File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/fet.lib.scs Section=\"TT\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/res.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/cap.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/bipolar.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/diode.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/ind.lib.scs Section=\"TYP\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/prelayout.lib.scs Section=\"ON\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/montecarlo.lib.scs Section=\"ALL_ON\";File=All#Global#/A/manas/manas/work_cad_IC616_130nm/DEV_MODEL/spectre_all/includes.scs Section=\"15M\";\"")
    funobj@0x46d6a2c8()
    funobj@0x46d6a138()
    funobj@0x46d69c00()
    funobj@0x46d69b60()
    *WARNING* (AMS-2002): Configuration properties have not been specified in Hierarchy Editor for the configuration.
    Those stack trace settings are now just showing errors which are caught - so aren't relevant here.
    I don't know what was causing the original problem, but exiting and restarting appears to have solved it.
    I suggest you restart again to avoid getting all the noise in the CIW, and just use:
  • RFStuff
    Thanks a lot Andrew.
