  2. Mixed-Signal Design
  3. How to Introduce a CDL Netlist for and Instance in AMS ...
  • Subscribers 64
  • Views 15547
How to Introduce a CDL Netlist for and Instance in AMS Simulation
baltacican87
baltacican87 over 5 years ago
I am using IC6.1.8-64b and xcelium 19.03.012. The simulator I am using is ams.
My goal is to run an AMS simulation where one of the cells in the schematic is introduced with a .cdl netlist file (a transistor level netlist). For that, I tried the combinations of the following and it failed in all cases:
  • I create a symbol for the cell and in the config view I introduced this cell as
    1. auCdl
    2. Mark ads External HDL
    3. Specify Spice Source File (.cdl file provided here)
  • In Simulation Files, I introduced the .cdl file under
    1. Include Paths (I provided the path to .cdl file)
    2. Definition Files
    3. PSpice Files AMS UNL Only
    4. Parasitic Files (DSPF) AMS UNL Only
I got two error messages depending on which combination I tried:
1)
xmelab: *F,OSSPDA: Instance 'X' of cell 'Y' is configured to a HDL cellview in Cadence Hierarchy Editor (HED). However, it is resolved to a SPICE primitive during elaboration. Revisit its configuration settings and design set up to resolve that inconsistency.
xmelab: Memory Usage - Final: 37.1M, Peak: 37.1M, Peak virtual: 108.1M
xmelab: CPU Usage - 0.1s system + 0.0s user = 0.1s total (0.1s, 68.6% cpu)
xrun: *E,ELBERR: Error during elaboration (status 2), exiting.
2)
Y X (.VSS( net8 ), .VDD( net7 ), …….
xmelab: *F,OSDINF (./netlist.vams,33|24): instance ' tb_Y.X' of design unit 'Y' is a leaf instance and is unresolved in cellview 'lib.tb_Y:schematic'. Ensure that the design unit is either pre-compiled or its corresponding text file is specified for compilation. Also, check the binding for this instance in Cadence Hierarchy Editor to confirm if it is set to externalHDL or addStopPoint or if nlAction is set to 'stop' for the specified instance.
xmelab: CPU Usage - 0.0s system + 0.1s user = 0.1s total (0.2s, 71.9% cpu)
How should I provide the .cdl file in my ams simulation so that the instance in the schematic connects with the netlist definition in this .cdl file?
Many thanks in advance.
Best regards,
Can
