  2. Mixed-Signal Design
  3. Transfer Layout from Innovus to Virtuoso: Layout pins issue...
  • Subscribers 64
  • Views 13017
Transfer Layout from Innovus to Virtuoso: Layout pins issue (interoperable between Innovus and Virtuoso using OpenAccess)
ayande1370
ayande1370 over 5 years ago
Dear all,
I want to use Open Access based flow to interoperable between Innovus and Virtuoso.
I have used lefin to convert the lef files (technology and standard cells library) to Open access.
lefin -lib libName  -overwrite -lef lefFileName -view abstract
Then, I have generated the layout in Innovus ( note that Innovus was initiated in Open Access mode.).
I have saved the place and route layout as an Open Access from Innovus and then reopen it directly in virtuoso, the problem is that the Virtuoso doesn't show the pins in the layout.
How can I get the pins in the Virtuoso layout?
Thanks in advance
