  2. Mixed-Signal Design
  3. *E,CUBSPA Assignment of string to real or integer type ...
  • Subscribers 64
  • Views 2787
*E,CUBSPA Assignment of string to real or integer type parameter
tpungi
tpungi over 4 years ago
I have a VAMS design with the following instance:
my_subckt #( .param1("2"), .param2("2.002u"), .param3("1.928u"))
// rest of code
And a SPICE subckt as:
.subckt my_subckt node1 node2 node3 param1=0.36e-6 param2=0.36e-6 param3=1
*rest of code
The amscf.scs block I am using looks like this:
amsd {
portmap subckt=my_subckt
config cell=my_subckt use=spice
ie vsup=1.8
When trying to compile the design using xrun I am getting the following Error:
xmelab: *E,CUBSPA : Assignment of string to real or integer type parameter.
The my_subckt is taken directly from PDK model library. And VAMs are also generated, using the same model library.
What exactly am I missing?
    It appears that they should not be strings - the parameters in the SPICE are floating point numbers, so I'm not sure why you have them set as strings on the instance line in the Verilog-AMS netlist. It should be:
    my_subckt #( .param1(2), .param2(2.002u), .param3(1.928u))
  • tpungi
    tpungi over 4 years ago in reply to Andrew Beckett
    Thanks for the reply.
    These .vams are generated by Virtuoso tool itself.
    So if that means I have to write a script to remove all the unnecessary " " to make it work.
    Andrew Beckett over 4 years ago in reply to tpungi
    No, you should not need to do this. Assuming that the netlister is stopping at this block, it suggests that the CDF for the cell is wrong and has the parameters marked as string types (probably OK) but doesn't have parseAsCEL or parseAsNumber set to yes for each of the parameters. So the CDF probably just needs fixing...
