  2. Mixed-Signal Design
  3. Noisy ac analysis result at low frequency
  • Replies 7
  • Subscribers 69
  • Views 18109
eyalg
eyalg over 5 years ago
When running ac analysis and plotting transfer function of amplifier I am getting noisy results at low frequency.
Its looks like accuracy of the simulator and when changing gmin it some times helps.
Is there a way to eliminate this noisy results?
  • eyalg
    I wouldn't expect that level of numerical noise, especially not when the gain is so high - that's rather strange. I also don't think that gmin would affect it, assuming that gmin is reasonable (near the default of 1e-12).
    Please contact customer support. This is rather unusual.
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to Andrew Beckett
    We have seen this kind of problem rather often, usually on RLCK-extracted circuits, and currently have CCR 2470950 open for such a problem. In this case, plain Spectre could simulate the circuit just fine while APS had big problems.
    Andrew Beckett over 5 years ago in reply to mize
    mize said:
    i am wondering is this type of frequency the same as that of online radio or radio television?
    Huh?
  • Frank Wiedmann
    Seems like we have another case of link spam here...
    Andrew Beckett over 5 years ago in reply to Frank Wiedmann
    Frank - it wasn't a link when originally posted (I checked). I'll delete the item and ensure that the user is blocked. I do wonder why people bother!
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago in reply to Frank Wiedmann
    You now might want to check if you get better results with SPECTRE 20.1 ISR13 or 21.1 ISR4 and later versions (see https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009favqEAA).
