  2. Mixed-Signal Design
  3. getData "noise" not listed in calculator
  • Subscribers 64
  • Views 2769
chrisindallastx
chrisindallastx over 4 years ago
Hi, I'm trying to get some expressions working in ADE Explorer that were used in ADEXL.
I have a working noise simulation, but I haven't been able to get an expression like:
value(getData("/vout" ?result "noise") 1000000)
to work. I noticed when I try to build it using the Calculator, that in the dropdown menu, "noise" isn't listed as an analysis type. Has this changed?
Thanks, Chris
    The output data of a noise analysis is not the name of the node. It's just called "out" - so you'd use getData("out" ?result "noise"). Or VN() or VN2() depending on the units you want.
    You specify the output node in the analysis set up itself - it computes the total amount of noise referred to that output node.
  • chrisindallastx
    chrisindallastx over 4 years ago in reply to Andrew Beckett
    Doh! The danger of having generic output names. Thanks, that was it exactly!
